Home > Maintenance & Modifications > Can you spot the backup camera?
sookoon
United States
The challenge of installing a backup camera on the defender is being able to see over the spare tire. By mounting the camera high up, on the rear task light, this also serves as a pedestrian safety improvement. No new holes drilled. The mounting bracket of the camera aligns perfectly with the extruded troughs of the handle of the task light, so the screws dive right in. Then, you can adjust the angle of the camera, and/or adjust the angle of the task light, for fine-tuning of your image.
Post #370177 7th Nov 2014 7:17pm
TJ101
Did mine somewhat different Wink
I wanted to be able to see the towball for easier hitch up,, so was fitted to the number plate lamp plinth,, so when with a small camera with built in led's..fairly discreet,, works a treat Thumbs Up
 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #370215 7th Nov 2014 9:22pm
Terryt
What cameras are you using guys......
Post #370218 7th Nov 2014 9:33pm
sookoon
United States
Damn, TJ. I like it. I think you just bested me.
TerryT, The camera I used has built in IR LEDs, and is model EONON A0112z, which you can find on ebay for about fifty bucks.
Post #370224 7th Nov 2014 10:04pm
TJ101
Good old E Blag for mine
http://www.ebay.co.uk/itm/141019667847?_tr...EBIDX%3AIT
It was a gamble, sounded like it would do the job,, as i wanted a small one to mount under the NP lamp, angle is wide enough to get a good back up view, and see the ball California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #370225 7th Nov 2014 10:06pm
VeeTee
Netherlands
Thumbs Up
Haha, mine four years ago:
 Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #370226 7th Nov 2014 10:06pm
TJ101
Re: Damn, TJ. I like it. I think you just bested me.
Rolling Eyes You found a good solution,, I looked for a while for the best place, if fitted to the top center, all you got was a good pictures of the spare wheel, in the way of the towball,,,as i was also upgrading to a LED NP lamp from MCL, seams a logical location
I wanted to resist drilling any holes !! yet ! I wired mine up into the reverse gear switch, as well as a separate dash switch, so can use the reverse light for general illumination with ign off California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #370229 7th Nov 2014 10:18pm
Terryt
Thanks chaps ..... Thumbs Up
Post #370255 8th Nov 2014 12:36am
fatman
Greece 2007 Defender 110 Puma 2.4 USW Keswick Green
Sookoon,i like the sticker on the rear windshield in ancient Greek!!
Post #370272 8th Nov 2014 7:11am
lukev01
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
TJ, love what you did.
Roughly what would it cost to get someone to instal your system? I would not try it myself, being a mechanical numty.
Also would it be possible to have the screen without doing anything to the dash.
I don't yet know if I will keep the 110 after 3 years, it will depend on what the new Defender is like so I want to keep everything standard or at least easy to get back to standard spec. 1970 Series 2A 88"
Post #370443 8th Nov 2014 10:08pm
TJ101
Hi
My screen is part of the sat-nag, audio system, (Pioneer single din, with motorized pop out screen,)
The camera was peanuts £20 odd from memory (link above somewhere ?) cable all ran forward in the side/roof panel, and down the A pillar,, you will need some form of screen, again cheap on e blag
As i was fitting a Led bumper plate lamp, the plinth had to be modified for than, so seams to best place for the camera
All my 110's, have been returned back to as standard as possible, hence not wanting to drill anything
As to cost ? 2/3 hours labour max (with a new screen,,really is a easy job) camera, and a screen California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #370603 9th Nov 2014 6:39pm
