![]() | Home > Maintenance & Modifications > Can you spot the backup camera? |
| TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752
Did mine somewhat different
I wanted to be able to see the towball for easier hitch up,, so was fitted to the number plate lamp plinth,, so when with a small camera with built in led's..fairly discreet,, works a treat Click image to enlarge Click image to enlarge Click image to enlarge California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
| Terryt Member Since: 28 Jun 2012 Location: Lerryn. Cornwall. Posts: 751
What cameras are you using guys......
| sookoon Member Since: 02 Nov 2014 Location: South Florida Posts: 41
TerryT, The camera I used has built in IR LEDs, and is model EONON A0112z, which you can find on ebay for about fifty bucks.
Good old E Blag for mine
http://www.ebay.co.uk/itm/141019667847?_tr...EBIDX%3AIT It was a gamble, sounded like it would do the job,, as i wanted a small one to mount under the NP lamp, angle is wide enough to get a good back up view, and see the ball California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
| VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512
Haha, mine four years ago: Click image to enlarge Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
I wanted to resist drilling any holes !! yet ! I wired mine up into the reverse gear switch, as well as a separate dash switch, so can use the reverse light for general illumination with ign off California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Thanks chaps .....
| fatman Member Since: 14 Jan 2014 Location: Athens-Greece Posts: 126
Sookoon,i like the sticker on the rear windshield in ancient Greek!!
| lukev01 Member Since: 24 Mar 2012 Location: Bedfordshire Posts: 412
TJ, love what you did.
Roughly what would it cost to get someone to instal your system? I would not try it myself, being a mechanical numty. Also would it be possible to have the screen without doing anything to the dash. I don't yet know if I will keep the 110 after 3 years, it will depend on what the new Defender is like so I want to keep everything standard or at least easy to get back to standard spec. 1970 Series 2A 88" |
Hi
My screen is part of the sat-nag, audio system, (Pioneer single din, with motorized pop out screen,) The camera was peanuts £20 odd from memory (link above somewhere ?) cable all ran forward in the side/roof panel, and down the A pillar,, you will need some form of screen, again cheap on e blag As i was fitting a Led bumper plate lamp, the plinth had to be modified for than, so seams to best place for the camera All my 110's, have been returned back to as standard as possible, hence not wanting to drill anything As to cost ? 2/3 hours labour max (with a new screen,,really is a easy job) camera, and a screen California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
