![]() | Home > For Sale & Wanted > [Wanted] canvas and stick set |
Bows Member Since: 07 May 2012 Location: Wales Posts: 525 ![]() ![]() ![]() |
Canvas and sticks for a truck cab 90
Thanks |
Either or, also considered. thanks
Andyred90 Member Since: 30 Mar 2013 Location: Wantage Posts: 482 ![]() ![]() |
Ive got a pick up canvas and stick but the canvas has a few holes and the rear plastic vision panel is torn.
Comes with sticks and all the fixings asking £165 [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861 ![]() ![]() |
Stick sets are cheap, series 3 ones are the same, hust need to lengthen the side bar, canvases are reasonable from all wheel trim.
Steve E
Thanks, I might end up doing the same but I'm not in a rush so i'll keep looking, surely theres one surplus to requirements somewhere. Andyred90 Thanks, I was hoping I would still be able to keep things dry in the back hence was after a slightly newer less worn canvas. Leenorthants Thanks, I thought there'd be an abundance of these with agri folk swapping them for Ifor williams or similar. Thanks for the replies guys, the search goes on. |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2076 ![]() ![]() |
The canvas roof doesn't make the rear water tight unfortunately.
They all have a gap at the cab end that let's water in. |
There is a rain gutter that sits behind the truck cab on the capping that takes the rain away.
Still looking ,
Unfortunately, this part does not actually fit the rear of the cab properly - many leak here & as mentioned above the LR canopy does not come far enough down the leading edge of the front sticks. It leaves a large gap for water to run into the tub. |
Thanks for your comments, I know of people with canvas hoods that fit fine and hold the water out well, the first pic posted above looks like it shows the canvas fitting nicely on to the gutter.
Thanks |
