Home > For Sale & Wanted > [Wanted] canvas and stick set
Bows
Wales 2006 Defender 110 Td5 SW Alpine White
Canvas and sticks for a truck cab 90
Thanks
Post #367830 28th Oct 2014 8:17pm
Bows
Either or, also considered. thanks
Post #368125 29th Oct 2014 9:58pm
steve E
Wales
Hi Bows
I was looking for a while and got to say second hand ones are like hens teeth.
In the end I got the hood on ebay from Bearmach in Caerphilly for £80.00
And the stick set from exmoor trim for £300.
Worked out half the price of an original from LR.
Hope this helps
Steve
Post #368133 29th Oct 2014 10:25pm
Andyred90
Ive got a pick up canvas and stick but the canvas has a few holes and the rear plastic vision panel is torn.
Comes with sticks and all the fixings asking £165
Post #368583 31st Oct 2014 9:22pm
Leenorthants
Stick sets are cheap, series 3 ones are the same, hust need to lengthen the side bar, canvases are reasonable from all wheel trim.
Post #368637 31st Oct 2014 11:18pm
Bows
Steve E
Thanks, I might end up doing the same but I'm not in a rush so i'll keep looking, surely theres one surplus to requirements somewhere.
Andyred90
Thanks, I was hoping I would still be able to keep things dry in the back hence was after a slightly newer less worn canvas.
Leenorthants
Thanks, I thought there'd be an abundance of these with agri folk swapping them for Ifor williams or similar.
Thanks for the replies guys, the search goes on.
Post #368680 1st Nov 2014 10:33am
steve E
Wales
The canvas roof doesn't make the rear water tight unfortunately.
They all have a gap at the cab end that let's water in.
Post #368697 1st Nov 2014 11:39am
Leenorthants
There is a rain gutter that sits behind the truck cab on the capping that takes the rain away.
Post #368785 1st Nov 2014 6:08pm
Bows
Still looking , Very Happy
Post #369610 4th Nov 2014 11:15pm
Unfortunately, this part does not actually fit the rear of the cab properly - many leak here & as mentioned above the LR canopy does not come far enough down the leading edge of the front sticks. It leaves a large gap for water to run into the tub.
Post #369675 5th Nov 2014 11:06am
Bows
Thanks for your comments, I know of people with canvas hoods that fit fine and hold the water out well, the first pic posted above looks like it shows the canvas fitting nicely on to the gutter.
Thanks
Post #369984 6th Nov 2014 8:21pm
