![]() | Home > Maintenance & Modifications > Replacing diffs, CV joints, half shafts etc at the weekend. |
| Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982
You may want to renew both the bearings. They are the same front and back. I asked a main dealer for an exploded diagram of the relevant part with part numbers. This was e-mailed to me and made the job easier. best to renew the seals as well, the diagram will show which ones.
When you renew the inner and outer bearings, just look at the colour of the spacer and adjust the end float to suit. Mine was a blue one so it was 0.175-0.250mm. It's in the Haynes manual (section 9/2), this works for a Puma as well as the bearings (LRSTC4382, £47 each original LR) are the same. Don't forget to order a new nut (LRRFD1000000), the old one will be severely dented when turned over. You'll need the seal, LRFTC4785 or cut one, as I did if you forget. When you pack the bearing with grease (messy job), use CV-2 synthetic grease. Don't buy sh*tpart, although their seals seem ok. Hope this helps, Merlin |
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039
It's a 1990 defender or still a Land Rover
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8481
dont be paying that much though if you do need them! Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
