Home > Maintenance & Modifications > Replacing diffs, CV joints, half shafts etc at the weekend.
Monmouth
Wales 1990 Defender 90 300 Tdi SW Firenze Red
I'm fitting a LSD and locking diff to my 1990 Defender this weekend along with other upgraded components such as CV joints and half shafts. While I'm pulling the axles to bits are there any seals/gaskets that are worth changing at the same time? 1990 Defender 300TDi
Post #368108 29th Oct 2014 9:27pm
Merlin
You may want to renew both the bearings. They are the same front and back. I asked a main dealer for an exploded diagram of the relevant part with part numbers. This was e-mailed to me and made the job easier. best to renew the seals as well, the diagram will show which ones.
When you renew the inner and outer bearings, just look at the colour of the spacer and adjust the end float to suit. Mine was a blue one so it was 0.175-0.250mm. It's in the Haynes manual (section 9/2), this works for a Puma as well as the bearings (LRSTC4382, £47 each original LR) are the same. Don't forget to order a new nut (LRRFD1000000), the old one will be severely dented when turned over. You'll need the seal, LRFTC4785 or cut one, as I did if you forget. When you pack the bearing with grease (messy job), use CV-2 synthetic grease.
Don't buy sh*tpart, although their seals seem ok.
Hope this helps,
Merlin
Post #368297 30th Oct 2014 4:32pm
roel
It's a 1990 defender or still a Land Rover Laughing So it has probably still the double nut system and no spacer between the bearings. Roel
2003 90 Td5 (2009-now)
Post #368325 30th Oct 2014 7:27pm
jst
dont be paying that much though if you do need them! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #368348 30th Oct 2014 9:06pm
