Home > Puma (Tdci) > Puma - What should i check when i collect
pom
I'm picking up an 08 90 county hardtop tomorrow, its a private sale and I got a good deal. It's still under LR warranty so not really too fussed, what things should I look out for though ?
what do I need to get the LR warranty transferred to me ?
cheers
Pom
Post #36681 21st Jul 2010 8:37am
jst
i believe you just register it with LR direct.
make sure you check SH as described and car is complete as detailed on the for sale add - right amount of tax etc! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #36686 21st Jul 2010 10:28am
spudfan
Ireland
Pull the bonnet and check all the fluid levels. Bit awkward to open the clutch reservoir-standard Defender thing this- but get the seller to open it for you. Lie underneath and check for any leaks. I had two engine oil filters that had very slight leaks. Follow the pipe work down from the reservoir for the power steering fluid just to make sure all is tight and there are no leaks. Mine leaked owing to a loose nut but I tightened it up and topped up the reservoir. No big deal. Make sure your handbook and all the other literature is in the vehicle. Start it up and turn it off. If there is a rattle from the clutch area as she is swithed off the clutch springs are rattling. Thie clutch will be changed under warranty. If there is a rattle when it is turned off depress the clutch pedal while turning it off. The rattle will not be heard. This will confirm the clutch needs changing. After that it is the usual cosmetics like elbow dents in wings etc. If you are happy strap you self in and join the "perennial grin on the face club". Odds are that you will get lost going home and only go home when you are getting low on cash!Sit back and enjoy, they are wonderful. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #36744 22nd Jul 2010 4:13pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Re: Puma - What should i check when i collect
Pom
Just by owning it transfer it over to you you don't have to do nothing Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #36748 22nd Jul 2010 4:23pm
Bosun
2008 Defender 90 Puma 2.4 XS CSW Tonga Green
Be warned!! Don't rely on the LR warranty. Times are hard and they don't like splashing the cash if they can help it. Take a good test drive and look for transmission freeplay (backlash) and gearbox synchromesh. If you can live with it fine, but if you can't, don't buy it!
Post #36765 22nd Jul 2010 7:36pm
fekete
How do you work that out then ? i've had over £5000 spent on mine and its out of warranty and they are still spending more on it ???
Sorry got it wrong £8000 NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #36782 22nd Jul 2010 11:13pm
Froogle-Yorkshireman
2010 Defender 110 Puma 2.4 USW Stornoway Grey
That's why wants rolling off the production line is a little shoddy....
They have spent all the money on yours fekete! Shocked
Post #36794 23rd Jul 2010 6:21am
