![]() | Home > Puma (Tdci) > Puma - What should i check when i collect |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8396 ![]() ![]() ![]() |
i believe you just register it with LR direct.
make sure you check SH as described and car is complete as detailed on the for sale add - right amount of tax etc! Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
Pull the bonnet and check all the fluid levels. Bit awkward to open the clutch reservoir-standard Defender thing this- but get the seller to open it for you. Lie underneath and check for any leaks. I had two engine oil filters that had very slight leaks. Follow the pipe work down from the reservoir for the power steering fluid just to make sure all is tight and there are no leaks. Mine leaked owing to a loose nut but I tightened it up and topped up the reservoir. No big deal. Make sure your handbook and all the other literature is in the vehicle. Start it up and turn it off. If there is a rattle from the clutch area as she is swithed off the clutch springs are rattling. Thie clutch will be changed under warranty. If there is a rattle when it is turned off depress the clutch pedal while turning it off. The rattle will not be heard. This will confirm the clutch needs changing. After that it is the usual cosmetics like elbow dents in wings etc. If you are happy strap you self in and join the "perennial grin on the face club". Odds are that you will get lost going home and only go home when you are getting low on cash!Sit back and enjoy, they are wonderful. 1982 88" 2.25 diesel
Just by owning it transfer it over to you you don't have to do nothing ![]() |
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 ![]() ![]() |
Be warned!! Don't rely on the LR warranty. Times are hard and they don't like splashing the cash if they can help it. Take a good test drive and look for transmission freeplay (backlash) and gearbox synchromesh. If you can live with it fine, but if you can't, don't buy it!
How do you work that out then ? i've had over £5000 spent on mine and its out of warranty and they are still spending more on it ???
Sorry got it wrong £8000 NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
Froogle-Yorkshireman Member Since: 10 Jul 2010 Location: Yorkshire Posts: 352 ![]() ![]() |
That's why wants rolling off the production line is a little shoddy....
They have spent all the money on yours fekete! ![]() |
