Home > Maintenance & Modifications > Door Bolt Problem...what would you do ?
X4SKP
Hello All… Can I have your help Question
I removed a door bolt recently, on the bulkhead side of the hinge, and in doing so heard a sound like a rejected coin in a parking meter... Shocked as the ‘retaining nut’ designed to stay in place didn't.
Two problems immediately presented themselves…
1. Unlike, or possibly like a parking meter, no rejected part fell out the bottom of the Defender.
2. I need to fix this.
So my fix currently is to remove the hinge block, or swing it out of the way enough to insert an M8 Long Reach SS Rivnut, (shown in photo) then probably adjust the plastic / rubber separating layer between the hinge and the bulkhead to sit around the head of the Rivnut in situ.
(The top bolt failed and is currently plugged to stop water getting in).
This route currently looks more attractive right now than trying to get to the missing (non) retaining nut or at least the position where it should be and install a new (better) retaining nut within the Bulkhead.
I assume that getting to the back of this Bolt position involves progressively removing my interior which I could do but are reluctant.
Here's the Questions
Do you agree (Rivnut Route over an alternative)
Have I missed something (very possible as this is new territory for me)
What actually should be on the other end of this bolt (within the bulkhead)
Has this happened to anyone else (if so what did you do)
Your help would be appreciated... Thumbs Up
Thanks SKIP
Post #365440 18th Oct 2014 4:04pm
mikeh501
The hinge clip is sitting at the bottom of your door channel. It will continue to rust away nicely until it's removed. Laughing
I found 3 in one side when I renewed my doors from previous owners Mr. Green
It's easy to remove. You need to remove the entire hinge block from the body side and then use one of those grabber things or long nose pliers to fish it out from the position of the bottom hinge. Good idea to waxoyled whilst your in the cavity.
Just get a new one from Land Rover. They are about 20p or something.
Post #365443 18th Oct 2014 4:21pm
munch90
if you undo both bolts and swing hinge round out of the way , im sure the internal nut is in a captive cage and is just slotted in from the outside , you don't need to take anything off inside
Post #365444 18th Oct 2014 4:21pm
X4SKP
munch90 and mikeh501 Thumbs Up
Thanks... got it (the advice not the lost nut).
Something like this then (not the correct size but type).
The Rivnut idea is now out, if your right (and I'm not doubting it) I will find a square hole when I get there,
so I will try to find the original, fish it out and refit it, or replace it if lost.
My 90 has been Dinitroled, but it's a good point you make mikeh501.
Thanks for the quick advice... SKIP
Post #365447 18th Oct 2014 4:46pm
munch90
thats the sort of thing
think there is three holes in the bulkhead under the hinge ,two bolt holes think there square and one bigger square hole in the centre where the nuts slide up in
when you fit the bolts back in cover the threads in waxoyl or something (or just dip the whole bolt in it )
Post #365450 18th Oct 2014 4:58pm
GUM97
Yep, square hole in the bulkhead if I remember rightly! (It's been about 2 years since I fitted new hinges!) so a captive nut in the square bracket is what's needed Thumbs Up An engine to TDi for!
Post #365454 18th Oct 2014 5:18pm
mikeh501
Mine looked like this. The fixing is more a captive clip than a nut. Got a full set off ebay, just had to find the part number.
The fixing slips over the round holes using the square middle hole as you push it onto the panel. Easy to drop them when fitting as they need a firm shove.
[/img]
Post #365466 18th Oct 2014 5:40pm
Happyoldgit
Yep, square captive nuts that slide / clip into place. Keep the door shut, undo remaining hinge bolt, clip in new captive nut, swing hinge back into place, apply copperslip to bolt threads before refitting and tightening. Easy peasey.
Always worth keeping a few spare captive nuts if you intend to make habit of mucking about with the hinge to bulkhead bots Thumbs Up Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #365468 18th Oct 2014 5:54pm
X4SKP
Thought I would tackle this, so got the tools out ...
Nothing (apparent) at the base of the lower hinge channel...
The top hinge then revealed 1/2 a retaining nut with the 'sprung' cage fractured...
Off to Land Rover for a replacement,
Thanks for your help with this... SKIP
Post #365591 19th Oct 2014 9:34am
If they won't stay in place perhaps clean it all up and use a spot of superglue.
Thumbs Up
Post #365594 19th Oct 2014 9:48am
dorsetsmith
or replament J nuts
Post #365597 19th Oct 2014 9:59am
X4SKP
Thanks custom90steve but I was thinking more along the lines of...
 SKIP
Post #365602 19th Oct 2014 10:11am
redzob
Guernsey 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
I did exactly the same thing when I was replacing the bolts for stainless. Got one of those magnets on the end of an aerial things - possibly the best £8 I've ever spent. As I progressed, I got used to leaving the magnet up against the rivnut (and bolts) and never lost another one. Defender Puma 2.2 XS 90
Vespa GTS 300
Way too many racing bikes.
Post #365603 19th Oct 2014 10:11am
X4SKP
dorsetsmith wrote:
or replament J nuts
Thanks dorsetsmith
I will probably drop in to a Land Rover as I am passing my local dealer tomorrow, and I should get out without the need to sit down in reception have a 'free' coffee and recover from their parts pricing policy on this one.
I wasn't expecting the cage / clip to break as it has, some kind of spring steel, which has not been repeatedly disturbed and so work harden and fracture... but there you go. SKIP
Post #365606 19th Oct 2014 10:19am
dorsetsmith
New repair part list for land rover
duck tap large roll
WD40 large tin
blue tack lots or better still ELDRo dum dum Thumbs Up
not new one old hotted up on the spot repair
Post #365609 19th Oct 2014 10:26am
