Home > Td5 > Td5 (1999) clicking noise from instrument cluster
travelrover
Australia 1999 Defender 110 Td5 PU Fuji White
Hi all
I have a clicking noise emanating from the instrument cluster. It is intermittent and alters in volume and appears to be roughly related to road speed but not always. My research tells me that I don’t have a speedo cable so I have no idea what may be creating this noise which is starting to drive me nuts. Any ideas?
Cheers - Simon
Mr. Green
Post #363259 8th Oct 2014 11:22pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
Relays often click, sometimes when they are not functioning correctly. Check that all your electrics are working. There are a handful of relays that just lie at the bottom of shelf behind the instrument cluster. 1998 110 300Tdi White Hard Top
Post #363260 8th Oct 2014 11:31pm
g-mack
is your speedo digital? My 109 thread
my youtube channel
Post #363263 9th Oct 2014 12:00am
Interlet
All TD5s had digital speedos. 1998 110 300Tdi White Hard Top
Post #363282 9th Oct 2014 7:58am
travelrover
Hi
thanks for your replys, yes all the eletrics are working well. the noise is getting louder over time.
Post #365123 17th Oct 2014 5:30am
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Is it dependant on what you have switched on. Does it occur when you have your lights, radio and heather/blower off? www.td5.org
Post #365126 17th Oct 2014 6:48am
mk1collector
I could be the bonnet rattling in the hinge as this cand sound like a light tapping. To test you can stuff a small bit of rubber or cloth in the top gap of the hinge bush and take her for a drive.
Post #365145 17th Oct 2014 9:27am
travelrover
@ me@td5.org
I have turned everthing off, lights, fan, radio(s), a/c all together and invidually (every combination) and at first I thought it had made some difference, particulalry to the volumn of the noise (quiter) but I am now not so sure. Either way the noise is still there and still appears to have some relationship to vehicle road speed and still comes and goes.
It is not the bonnet rattling.. it definitly eminates from the instrument cluster
Any other thoughts?
Simon
Post #366809 24th Oct 2014 1:49am
munch90
is the mileage display digital ?
Post #366810 24th Oct 2014 4:07am
travelrover
yup, everything else appears to be normal...
Post #366811 24th Oct 2014 4:42am
ibexman
It's not yours keys in the ignition rattling is it Whistle
Post #366815 24th Oct 2014 6:47am
travelrover
noooo.... not the keys Wink
Post #366816 24th Oct 2014 7:11am
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Could it be the speedo head itself ? Try disconnecting the wire from the speedo transducer ( on the back of the transfer box behind the transmission brake drum) and see if the noise stops without the speedo working. 2005 Td5 90 XS
Steve
Post #366830 24th Oct 2014 9:31am
