![]() | Home > Td5 > Td5 (1999) clicking noise from instrument cluster |
travelrover Member Since: 19 Nov 2013 Location: East Kurrajong Posts: 5 ![]() ![]() ![]() |
Hi all
I have a clicking noise emanating from the instrument cluster. It is intermittent and alters in volume and appears to be roughly related to road speed but not always. My research tells me that I don’t have a speedo cable so I have no idea what may be creating this noise which is starting to drive me nuts. Any ideas? Cheers - Simon ![]() |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
is your speedo digital? My 109 thread
my youtube channel |
Interlet Member Since: 10 Oct 2011 Location: Norwich Posts: 461 ![]() ![]() ![]() |
All TD5s had digital speedos. 1998 110 300Tdi White Hard Top
Hi
thanks for your replys, yes all the eletrics are working well. the noise is getting louder over time. |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
Is it dependant on what you have switched on. Does it occur when you have your lights, radio and heather/blower off? www.td5.org
I could be the bonnet rattling in the hinge as this cand sound like a light tapping. To test you can stuff a small bit of rubber or cloth in the top gap of the hinge bush and take her for a drive.
@ me@td5.org
I have turned everthing off, lights, fan, radio(s), a/c all together and invidually (every combination) and at first I thought it had made some difference, particulalry to the volumn of the noise (quiter) but I am now not so sure. Either way the noise is still there and still appears to have some relationship to vehicle road speed and still comes and goes. It is not the bonnet rattling.. it definitly eminates from the instrument cluster Any other thoughts? Cheers Simon |
is the mileage display digital ?
yup, everything else appears to be normal...
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
It's not yours keys in the ignition rattling is it
noooo.... not the keys
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Could it be the speedo head itself ? Try disconnecting the wire from the speedo transducer ( on the back of the transfer box behind the transmission brake drum) and see if the noise stops without the speedo working. 2005 Td5 90 XS
Steve |
