Home > Technical > Stripped transfer box
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
I have a secondhand transfer box to replace the knackered one on the 110 however the drain plug has sheared off and it looks as if the thread in the casing has had it too.
Is there an oversize replacement plug that can be made to fit? Am trying ovoid going down the route of a helicoil if I can.
Any other suggestions would be great especially if anyone knows of a Land Rover magnetic jobby that is bigger and can be retrofitted.
Dave
Post #363799 11th Oct 2014 5:11pm
X4SKP
Hi v8bobber
More info'...
'the drain plug has sheared off'...is some of it still in the casing Question
assume not as
'it looks as if the thread in the casing has had it too'... has it Question
If the entry few threads in the casing are stripped but the inner threads are ok
then match the drain plug thread with a longer bolt and use what a standard
drain plug doesn't reach...
Not sure of the exact arrangements on a TD5... but worth a look at Eric The Car Guy
Failing that then a Helicoil if there is enough material directly around the site to take it... should be. SKIP
Post #363814 11th Oct 2014 6:29pm
martinfiattech
Either way you will have to run a drill and tap down the hole, then find the right size bung / bolt to fit. So my self I would just fit a heli coil and keep to a standard bung.
I know there are lots of iffy comments about heli coils, but my self I use them on alloy gearbox casting`s on ducato`s and I`ve not had an engine fall out yet.
If your worried about the heli coil coming out when you undo the bung just add lock tight to the coil, then fit the bung the next day so it has time to cure, this has worked for me on many alloy sumps on old mini`s ( it`s cheaper than a new gearbox). Excuse the spelling I`am better with spanners and wires.
Post #363818 11th Oct 2014 6:59pm
The drain plug on an LT230 is in the inspection cover is it not? why not just swap that whole thing over (8x bolts IIRC)
job done.
Post #363826 11th Oct 2014 8:35pm
munch90
you can get proper sump plug repair kits
Post #363828 11th Oct 2014 8:39pm
munch90
job done.
drain plug is in the main casing
Post #363831 11th Oct 2014 8:50pm
Is it? sorry, I thought it was in the inspection cover Embarassed Embarassed
Post #363832 11th Oct 2014 8:51pm
munch90
that's ok , i just posted a idea and got the wrong thread size so had to delete
the series transfer box had the drain plug in the cover not main case
Post #363833 11th Oct 2014 8:56pm
v8bobber
I'm going with the option of tapping the thread out to a bigger size and fitting a bigger drain plug
I'll let you know how I get on
Post #364024 12th Oct 2014 10:19pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
I thought my drain plug had stripped but now realise it is the magnet that has come loose as in this and many other threads. V8bobber, how did you get on?
Munch90, do you have any details on the repair kits you mentioned? 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #440787 27th Jul 2015 8:20pm
munch90
Plenty of sump plug repairkits on ebay , of course all different sizes
what plug you doing ?
Post #440798 27th Jul 2015 8:46pm
Dave T
It's an lt230 Tx box 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #440800 27th Jul 2015 8:53pm
munch90
I THINK its m12x1.5 thread , you would need to double check this
if so then this should do it
eBay Item No. 160944766218
make sure to tap goes in dead straight, otherwise the copper washer wont sit flat
Post #440808 27th Jul 2015 9:09pm
Dave T
brilliant, thanks.
I'm hoping my threads are ok, the bottom bit screws in nice and tight, its just the magnet is stuck at the top blocking off the hole, but this is a great looking fall back for if they have gone 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #440859 28th Jul 2015 6:56am
