Home > My Defender > Puma Gearchange
Howard650
Puma Gearchange
Hi All
I realise I will be potentially castigated for this but I feel I should share Embarassed
As I posted before with my new to me 2012 puma I had been having the old gear change problems. Well today I thought I would have a run over to my local approved Land Rover Dealer and get myself associated with them. As I was their I asked for one of the Mechanics to have a quick run and give me his opinion. He quickly told me that he thought their was not enough Clutch travel in his opinion. After removing the Land rover rubber mats which the dealer had thoughtfully fitted when I bought it the difference in gear change was a revelation.
The Mechanic told me that recently one defender owner has had two clutches replaced for the same reason. Each time he brought his defender in without the mats and it was only when they asked if used mats that the reason became apparent.
I realise I may look a bit foolish but I thought I would post in any case, hope this helps someone at least!
Post #363513 9th Oct 2014 10:53pm
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi,
thanks for the story even if incredible !
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #363528 10th Oct 2014 6:43am
JustStarting
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Barolo Black
Glad I read this today Rolling with laughter
I have the heavy duty rubber mats in mine on top of the standard carpet mats. I know know why the clutch travel is so restricted!! MY2015 110 Urban Truck Expedition Spec
2005 Td5 TwinCab
1998 110 CSW 300tdi
Post #363758 11th Oct 2014 10:54am
X4SKP
Hello Howard650
You are right, thanks for posting a 'brave' observation.
I have seen this before, at my local independent, where Defenders that have 'Matted Up'
(or changed / added Carpet in an attempt to quieten things down) then experienced Gear change issues...
and the dots have not been joined up.
This can also easily result if an acoustic sound block material is used in the footwell... as well Exclamation
I have the standard LR Carpets, then a closed cell neoprene liner, then the Defender Mat and my Clutch Pedal just makes contact when fully depressed. (on its lower edge) but fully activates the clutch before this point.
This is definitely something to be aware of, as the clutch wares and the pick up or disengage point slowly changes.
I plan a Dynamat Sound Proofing exercise soon, and will have to be careful in this area.
On a standard set up, Carpets + LR OEM Mats there shouldn't be an issue... but maybe there is Embarassed SKIP
Post #363775 11th Oct 2014 1:11pm
captain slow
United Kingdom 2014 Defender 110 Puma 2.2 CSW Corris Grey
time to get the scissors out to trim the mat around the clutch?? 2.2 Tdci 110 XS CSW Corris Grey
Prince Harry's D3 (gone but not forgotten)
300 Tdi 110 CSW (gone but not forgotten)
Post #363776 11th Oct 2014 1:18pm
gilarion
The same thing can happen to the throttle / accelerator pedal resulting in a rarely achievable full throttle Whistle
Post #363778 11th Oct 2014 1:40pm
X4SKP
...better check the Throttle at the same time captain slow Shocked SKIP
Post #363782 11th Oct 2014 2:02pm
captain slow
Laughing Laughing Laughing Laughing Laughing 2.2 Tdci 110 XS CSW Corris Grey
Post #363783 11th Oct 2014 2:21pm
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
Isn't there an adjustable rod in the clutch master-cylinder box that would avoid the need to do this? 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #363786 11th Oct 2014 2:34pm
Howard650
I have the standard carpet and the OEM Mats and it was enough to restrict the clutch travel. As Captain Slow suggested I just snipped out the corner of the mat. Certainly has made a big difference.
Glad this post seems to have helped!
Post #363834 11th Oct 2014 8:57pm
Howard650
Found these pictures on another post regarding the shape of mats fitted.
The first one is an image of the "New" shaped mats with the corner missing which would allow full travel on the clutch:-
The second image shows the older square type mats as fitted by the dealer in my 2.2 which caused the fouling. Looks like it was a case of the dealer fitting the wrong mats maybe?
Post #363853 11th Oct 2014 10:22pm
bear100
A bit off topic Rolling Eyes but I had a new 2011 Range Rover sport, after the usual haggling with the dealer had a new set of rubber matts, unknown to the dealer the MY2010 mats and earlier must not be fitted to the later models, when the accelerator is pressed hard the mat traps in the peddle Shocked a very scary moment. After a hard chat with the dealer I came away with champagne, new matts and discount servicing Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #363876 12th Oct 2014 8:10am
AndrewS
Cut the bottom of the pedal off Thumbs Up
Post #363881 12th Oct 2014 8:42am
munch90
the master cyl rod shouldn't be touched as adjusting can result in clutch not releasing completely causing bearing failure
also not getting proper movement of the pedal causing less movement of the piston in the cyl causing clutch drag
the pedal needs to be resting on the top stop then cyl rod has to be right out and have a couple of mm free play before pedal pushes the cyl piston
it has to be set in the right place and left alone
Post #363884 12th Oct 2014 8:58am
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Checked my MY2013 and I have the full mat as shown on the left. Mt clutch goes fully to the floor with the mat fitted and the factory fitted sound proofing with no issues.
Post #364209 13th Oct 2014 7:21pm
