![]() | Home > Tdi > 300tdi boost |
| markns Member Since: 24 Apr 2013 Location: Halifax Posts: 2
Great to hear your results... I've got the same setup as yourself (turbo/intercooler) and have been reading the same recommendation on the defender source forum. Any chance of seeing a photo of your connections?
Also wondering where your fueling is set at (diaphragm cone position), did you need to adjust it or the turbo afterwards? Thanks. |
| Alex1976 Member Since: 24 Jan 2013 Location: Buckingham Posts: 596
Click image to enlarge Click image to enlarge Click image to enlarge I have already adjusted the feeling up both on the cone and also on the max fuel at the rear of the pump. This change to the boost now seems to make it run cooler (EGT) as well as more power. Really pleased with the results. |
| g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967
very nice set up
my youtube channel Last edited by g-mack on 7th Jan 2017 1:55am. Edited 1 time in total |
cheers gmack! Yep I do have engine bay OCD!
Thanks for the photos... Agreed, that's tidy bit of work
You've inspired me to follow suit...though I'm sure it won't look quite as nice. Any boost readings or comparisons? (I'm sure they are similar just timed better to the FIP...) I'll let you know the results on this side of the pond. Thanks again! |
| Defender_Td5 Member Since: 20 Jul 2009 Location: Devon/Australia Posts: 69
Hi Alex,
I also have the same turbo set up on my 300Tdi. When you say you took off the "pipe to the FIP from the turbo" did you blank the outlet on the turbo itself? As I understand it (and from you pictures), the pipe from the fuel injection pump goes into the bottom of your T-Piece, one side goes to the intake manifold at the back and the other side of the T-Piece goes to the wastegate actuator. If so that would leave an outlet on the compressor side of the turbo...I think... If this is the case, do you know the correct size thread for the turbo compressor outlet? Here is my current set-up, it nice to see someone else with engine bay OCD as well haha: Click image to enlarge. What is the physical effect of this set-up? Does it cause the wastegate to open at a different time? To be honest my VGT is a much quieter turbo than the standard 300Tdi Turbo offering, and I kinda of miss the turbo whistle! Cheers Rob
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Last edited by Defender_Td5 on 6th Oct 2014 10:56am. Edited 1 time in total |
how the hell do you get it like that?? no matter how hard i try i cant get my filter to turbo hose looking good! thinking only way is buy a new one. unless you have any concours guru tips my youtube channel |
Darn you saw through my cunning plan....well you see it is NEW, everything was new...even my engine....
aw man, im totally jealous! lol that must be an awesome tdi you have there! would love to see more! My 109 thread
See here for the build thread:
http://www.devon4x4.com/index.php?option=c...Itemid=106 Awesome Tdi: Well it is and it isn't. Despite the following mods it still doesn't go anywhere near as well as I think it should! - VNT from IRB - Allisport drop-in replacement intercooler - Rebuilt Turner Engineering 300Tdi with AMC Turner Performance Cylinder head - Uprated fueling (diaphragm turned and starwheel) - Donaldson "Wolf" spec airitake. I initially thought it was because the engine was "tight" after the rebuild, but after 12,000 miles I am still looking for more get up and go. Last edited by Defender_Td5 on 7th Oct 2014 12:08am. Edited 1 time in total |
Rob, i bow down to you man!!!!
read your build thread from start to finish. I have to say that your build is without doubt the most thorough i have seen!!! if i could choose any of our members cars in a heartbeat it would be yours!!! awesome job man!!!!awesome!! My 109 thread my youtube channel |
Cheers G-Mack, a lot of blood, sweat and tears went into it! Took almost 3 years in total, although the final part was thrashed together in a month because I had moved to Aus by that time.
Maybe I should put the build thread on this forum so others could take a look? Anyone have any answers to my initial post...the O/P seems to have disappeared! Cheers Rob Last edited by Defender_Td5 on 8th Oct 2014 10:28pm. Edited 1 time in total |
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
YES PLEASE |
Hi Rob,
Sorry for the delayed reply. Work has been crazy busy so not much time to get on here! You guessed correctly about the pipe from the t piece going to the FIP. This does leave the outlet from the turbo that needs blanking. I have not yet found a blanking plug for it as it is an odd thread - I think it is a BSF thread. So I have just a temp blanking pipe on it at present. The actual effect of this mod is it ensures there is the full 1 bar of turbo pressure at the manifold by the turbo vanes moving to give more boost at any given engine revs. When the fuelling is matched to this you get a very useable increase in power. Probably just what you are looking for if you think your set up is not producing what you feel it should. Love your engine ocd! So pleased it's not just me! |
