Home > Technical > Cutting TD5 From Running
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
Hi All,
Just need to quickly check the best way to disable the TD5 engine from starting whilst still allowing it to turn over.
In my head, I have it as:
> Remove FPR Feed Pipe (Quick release fitting)
> Remove Fuel Pump Relay
> Turn It Over To Clear Left Overs
> Remove Injector Plug (May need to reconnect this, but should be ok once residual fuel is cleared)
Cheers!
Post #361937 3rd Oct 2014 4:14pm
JWL
Disconnect or take out the crank position sensor.
Post #361942 3rd Oct 2014 4:37pm
rallysteve
Unplug inertia switch on the engine bulkhead 02' 110 TD5 Double Cab Rebuild Thread
Post #361968 3rd Oct 2014 6:23pm
grafty99
Inertia switch Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #361992 3rd Oct 2014 8:33pm
^^^^ +1
Or if you can't be bothered to unplug it, just give it a whack, or if you're feeling strong, turn your rover over 360 degrees. Rolling with laughter
Post #361994 3rd Oct 2014 8:34pm
silky16v
England 2001 Defender 90 Td5 X-Tech LE Blenheim Silver
unplug injector loom
Post #362878 7th Oct 2014 3:39pm
Fatboy Slim
Wales
+1 on the injector loom. Quick and easy
Post #362881 7th Oct 2014 3:43pm
taazzukcb
Inertia plug did the trick, nice and simples Smile!
Post #363011 7th Oct 2014 10:34pm
