Home > Puma (Tdci) > Ultra gauge installation
Page 3 of 5 <12345>
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
2.2 Sad
but i can get over not having the temp. i know when i am cold Exclamation
the center ultra gauge isnt a problem on the 2.2 is it? just the temp?
Post #361075 29th Sep 2014 8:15pm
noworries4x4
Mine is a 2.2 but I only want the UltraGauge in the middle If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #361097 29th Sep 2014 9:00pm
SupraAyf
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
Nice work Mark, that's an impressive set-up you've got there. - Andrew -
Post #361119 29th Sep 2014 9:47pm
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
With a bit of careful craftsmanship and luck (based on light guides being the same distance apart) I think it might be possible to relocate the DPF LEDs to the area under the rev counter. http://defender90xs.blogspot.co.uk/
Post #361121 29th Sep 2014 9:49pm
mark_d
As an update for anyone who is interested in this modification:
A forum user is sending me a spare cluster to fit both a Check Temp and an Ultragauge. The modified centre support of the cluster with the 2 gauges will then be sent back so the original cluster can be clipped apart to replace the centre support with the modified one.
I'll be doing the CheckTemp a bit different to how it is shown in my blog to make it a tidier and more robust installation. The electronics will be embedded in the cluster, rather than sitting behind it.
The downside to this is that I will have to remove the relay that can switch the A/C on and off.
This isn't going to happen over night, but I'll update this thread with the progress.
Cheers,
Mark http://defender90xs.blogspot.co.uk/
Post #361472 1st Oct 2014 6:14pm
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
2.2. owner interest here, want to keep AC capability though of course. I look forward to seeing how this progresses. Thanks 2.2 90 XS
88" Series One
Old Norton Smile
Modern Honda and Harley
Post #361562 1st Oct 2014 10:37pm
daxmus
Germany
Hello from germany!
I'm trying to implement something similar. But I don't want to use something like the UltraGauge, i want to use a microcontroller and control a lcd myself.
Yesterday I tryed to disassemble the cluster and check the place I have to position the lcd. But I failed at the needles. Can you tell me, how to remove them? I tryed to pull them off, but it didn't work...
Or was I just too afraid to damage something?
Post #362200 4th Oct 2014 8:03pm
mark_d
Hi Daxmus,
You should squeeze and twist the needle anticlockwise while pulling the needle away from the dials.
They are just held on with friction.
I look forward to seeing your project. What sort of information do you want to display on the LCD?
Cheers,
Post #362224 4th Oct 2014 9:15pm
daxmus
Germany
Hi Mark,
Thanks for your reply! Hopefully i can try it within the next days.
I want to use the ELM327 chip, which is a quite common OBD2 interpreter, to communicate with the car. Probably the UltraGauge uses the same chip, so i should be able to display the same information.
But the differences are, that i can choose the color of the lcd myself, the design of the screens, icons, ...
Displaying data from external sensors should also be possible (oil temperature, exhaust temperature, ...). It would be easier, faster and cheaper to use a UltraGauge, but for quite some time i want to develop a sophisticated microcontroller project. Thatsway i do it on myself.
Post #362386 5th Oct 2014 7:17pm
mark_d
That sounds like a big project daxmus, good luck with it. I hope you will share the results Smile
I agree it is better to do things yourself as you don't have to compromise your design for others. http://defender90xs.blogspot.co.uk/
Post #362729 6th Oct 2014 9:23pm
mark_d
I've lined up the DPF lights with unused light guides in the rev counter, so for 2.2 owners who want the Ultragauge fitted, this could be a good solution Smile
Post #362730 6th Oct 2014 9:29pm
noworries4x4
Superb idea and well executed. If everything is under control you are not going fast enough.
No Worries 4X4
Post #362736 6th Oct 2014 9:45pm
chadjizz
noworries4x4 i agree.
im in for one mark, let me know how you get on with the current one and prices etc.
cheers
Post #362759 6th Oct 2014 10:31pm
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
Wouldn't the place of the Dark Display make a perfect location for a disassembled Apple Watch? Never forget: cars have owner, Landrover have field service personnel.
Post #362874 7th Oct 2014 3:29pm
daxmus
Germany
Yes, it will be a very big project...
But i will keep you informed!
My roadmap is:
- check how to fit the display (thanks to mark for the hint with the needles Smile
- think about the menu-structure and design of particular menu pages (what information should be displayed)
- think about the count of the needed switches to control all
- create the circuit layout
- build the curcuit and stasrt writing code
- test, test, test,...
- install it in the car and be happy Smile
I guess it will take time at least till next spring, because i can spend only a few hours per week on the project.
Post #362947 7th Oct 2014 7:22pm
Page 3 of 5 <12345>
