![]() | Home > Puma (Tdci) > Ultra gauge installation |
| mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266
Did this today. Not finished the project, but very happy with the progress so far
Click image to enlarge http://defender90xs.blogspot.co.uk/ |
| chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559
WANT WANT WANT
i have always looked at that empty space in my puma's and thought it needs something like that. can you put a how too up pleassssse. |
I've a few things to finish off, like the relocation of the buttons. Once I've done that I will do a write up on my blog.
I was really surprised the gauge screen fitted so perfectly. http://defender90xs.blogspot.co.uk/ |
| Cat81 Member Since: 05 Mar 2014 Location: Kent Posts: 60
This is really cool! Impatient to see the write up...
| TDCi Guy Member Since: 17 Aug 2014 Location: Yorkshire Posts: 286
I read your temp guage install the other day and wondered if this was possible, you've proved me right!
| H3nry Member Since: 08 Jan 2014 Location: Heathrow Posts: 134
Wow Wow Wow!
Want Want Want! |
| Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000
Looks great.
What a shame Td5's aren't OBDII compliant. |
| noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196
I asked on here recently if anyone had managed to do this, I have the ultragauge and I am still having difficulty getting it to show the info that I want, egt, turbo boost, oil temp, fuel consumption ect not the factory settings If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
And also how come you have info display on your rev counter ??? If everything is under control you are not going fast enough.
@noworries4x4 click on his blog link at the bottom of his post. Theres a write up for his ambient temp guage install (in the rev counter) on there
This is a bit more straight forward than the Check Temp install. It does require a bit of soldering, but nothing too difficult and no special parts like the Check Temp. http://defender90xs.blogspot.co.uk/
| SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455
You could very easily go into business with this mod - installing a temp guage and ultra guage using a postal service - I for one would bite your hand off.... My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
| redzob Member Since: 16 Jul 2014 Location: St. Peter Port Posts: 137
+1. i'd pay for one of these setups through the post... Defender Puma 2.2 XS 90
Vespa GTS 300 Way too many racing bikes. |
In terms of the Ultra Gauge - I'd be happy to do this modification for others.
Having a scrap instrument cluster to have ready modified so it can be turned around in a day would be good. I wonder if any of the Forum sponsors have a broken cluster gathering dust. The Check Temp isn't as tidy to install, but if I get a spare cluster I could look at the possibility of doing it differently. http://defender90xs.blogspot.co.uk/ |
