![]() | Home > Off Topic > Shellshock - computer vulnerability |
| Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230
There is a serious computer vulnerability that has been found which has the potential to be worse than HeartBleed. Companies seem to be working on a fix, but please be careful..
More information can be found searching for "ShellShock". or http://www.theregister.co.uk/2014/09/25/sh...ype_fears/ Kindest regards |
| X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304
These types of attacks will be an ongoing issue…
I was once told there are two types of people, those who have had a data loss and those who are going to have a data loss. Back up your data and then back up your back up’s. Run quality internet security. Use secure purchase options on-line. Change your pass-words to high ranking ones. Try to avoid… SKIP
https://www.defender2.net/forum/topic83242.html |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
Just run the test to see if my mac is vulnerable and sure enough it is - come on apple pull your finger out and let's have a patch please.
This is how I checked
In the meantime I am having kittens, I suppose it is payback time for all the times I have felt smug about pc attacks and viruses. Barbara |
| davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888
You put your Mac on the internet ? Do you run a web server on your Mac ?
Unless they have access to run Bash scripts already via a login then it's not an issue for machines that are not accessible from the outside world. Potentially the weakness could be exploited via a trojan application though so be careful what you install on the Mac or just use the security settings to block unsigned apps. Go to System Preferences -> Sharing and make sure "Remote Login" is turned off. The main vulnerability is for web servers, particularly those that allow direct cgi execution although no doubt there will be further ways to exploit it. Potentially a php script could be used to trigger it but if they've already managed to run arbitrary php scripts then you already have issues. http://www.yorkshireoffroadclub.net/ |
| VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512
^ Thnx for the explanation Dave.
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Thanks Dave - always the voice of reason
Barbara |
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
Okay - I'm vulnerable. Now what?
Doesn't seem to be much advice except "don't use credit cards etc." I don't have much option as I'm stuck in Germany p.s. still using the app But shout it at them in German because life is also terrifying and confusing... |
| scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571
Let's not forget that Linux machines are ridiculously less vulnerable than Windows machines anyway. I know which OS I prefer to run and do any sort of banking transactions on and that hasn't changed in the last few days or so.....
| AndyS Member Since: 18 Aug 2012 Location: London Posts: 597
It's not that hard to avoid these attacks, they require you to either click on a link to download the virus or open a file sent to you in an email. So don't visit dodgy websites, click on links emailed to you by unknown people or open files sent to you (they usually appear as a zip file in an email saying 'your invoice is attached').
| All times are GMT |
