Home > Technical > Removing a cat on a 2011 Defender 110 2.4 Puma
Page 2 of 2 <12
K9F
What even with one of his maps? Good excuse to get a hybrid one then. Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #360142 25th Sep 2014 7:47pm
munch90
dgardel wrote:
but the reduced backpressure can shorten the turbo life. Ask to BAS.....
what happens to the turbo to shorten its life ?
what happens with less back pressure ?
Post #360146 25th Sep 2014 7:53pm
I think that without sufficient backpressure the turbo can spin too fast (think of the back pressure as a buffer to stop the exhaust gas from leaving too quickly)
With the turbo going too fast it can cavitate... whatever that means.... sounds expensive though... Laughing
Post #360230 26th Sep 2014 8:03am
munch90
cavitate means it spins so fast that it doesn't actally move anything , water pumps can cavitate (they spin in they own pocket of bubbles ) if spun to fast and its common to fit a bigger drive pulley to slow the pump down on a race engine that revs higher than standard and it eat the impellor away
some ford engines used to suffer with porus blocks if you didn't run antifreeze , said to be caused by the small bubbles collapsing , bit like a ultrasonic cleaner (the bubbles were said to eat the block away inside )
I think its mainly to do with fluids not sure if a turbo can cavitate
thought you may like to know !!!
Post #360234 26th Sep 2014 8:30am
Thumbs Up
Every day's a school day!
Post #360237 26th Sep 2014 8:53am
SupraAyf
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
Does anyone know the standard boost pressure of a healthy turbo running with a cat fitted against the potential boost spike readings of a turbo with the cat removed.
Also, what boost pressure reading activates an over-boost DTC? - Andrew -
Post #360406 26th Sep 2014 10:40pm
landy andy
Any fan / impeller / propellor can canvitate.
Andy
Post #360420 26th Sep 2014 11:13pm
AntonioSC
Brazil 2011 Defender 110 Puma 2.4 SW Alpine White
Many thanks, guys. The "surgery" photos were great.
Best
Post #360434 27th Sep 2014 12:19am
dgardel
Italy
W/o the correct backpressure, when you release the thottle, the turbo continue to spin for inertia.
But engin not more demand for air so the "air column" push the impeller in the exhaust direction very hardly and the axial bearing (not the rotating bearing called radial) could fail....
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #360439 27th Sep 2014 5:57am
munch90
trouble is any back pressure is going to be so changeable due to revs and load on the engine , exhaust has to cope with gas flow from tick over (none) to full throttle (lot more)
i know what you mean by load on thrust bearing , but not sure this could be a issue (you see alot of turbos with just a stub exhaust where noise isnt a issue and they cant have any back pressure
as you lift of throttle there cant be much if any increase in pressure (to put any more load on impellor) as there is no butterfly in the inlet any excess pressure will go into engine and intercooler , hoses etc
right size of exhaust on a n/a engine is inportant as you want exhaust gas scavenging effect something not really needed on turbo engine
Post #360455 27th Sep 2014 9:27am
Page 2 of 2 <12
