Home > Technical > Removing a cat on a 2011 Defender 110 2.4 Puma
AntonioSC
Brazil 2011 Defender 110 Puma 2.4 SW Alpine White
Hi everyone.
I own a 110 and am bothered by the intermitent but persistent vibrations (metallic noises) that come out from the catalyser since I first purchased the car (brand new). Cannot count on a LR dealer as they refuse to acknowledge the problem (yes, the car is still under warranty).
My mechanic says that, apart from a small increment in emissions, no other problem will result from removing the internal parts of the cat. However, someone else has suggested me remove the whole cat box and replace it by a 63 mm diameter pipe, a common procedure, according to him.
How different can the outcome be if (i) the whole cat box is removed or (ii) just the internal parts of the cat (ceramics etc), ie, keeping the metallic outer? By "outcome", I mean reduction in performance, additional fuel consumption, change in noise, darker smoke etc.
Lastly, why so many people, according to one of my sources, remove the whole cat box? Is it all related to annoying vibrations, just like in my case, or they aim at another target?
Really appreciate your views on that.
Antonio
Post #357044 10th Sep 2014 2:44pm
Naks
I removed the internals, no issues whatsoever.
Cheapest way to get rid of the cat Thumbs Up --
Post #357057 10th Sep 2014 3:34pm
AntonioSC
Many thanks, Naks.
What was the motivation for you to do that?
Regards.
Post #357076 10th Sep 2014 5:36pm
K9F
Do a search under 'decat' there is loads of threads listing all the benefits of decatting. Still one of the best and cheapest modifications you can do in my opinion.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #357079 10th Sep 2014 6:02pm
Naks
reduce EGTs, decrease cabin heat soak, etc.
turbo also spools up a little bit quicker at low revs.
Thumbs Up --
Post #357098 10th Sep 2014 7:02pm
AntonioSC
Hi guys:
Just to add that I'm simply trying to get rid of the irritating metal noise without having to buy a new and pricey cat. I want to keep the original characteristics of the car as much as possible: performance, noise level, smoke aspect etc as I'm not involved in any car tuning or the alike.
Post #357110 10th Sep 2014 7:42pm
Landy-Novice
take it off, cut it open beat the internals out and weld and refit. Thumbs Up
Post #357504 12th Sep 2014 6:43pm
AntonioSC
Thank you all.
Regards
Post #358118 16th Sep 2014 12:31am
Fish
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Just bash them out no need to cut. Also improves fuel efficiency..
Post #359716 23rd Sep 2014 12:59pm
AntonioSC
Hi Fish:
You mean bash the internals out?
Regards,
Antonio
Post #360035 24th Sep 2014 10:26pm
Slightly O/T... my sister just had her cat removed from her brand new Evoque....
but that's because it crawled up into the engine bay when she parked up, and got cooked.... Whistle
Post #360059 25th Sep 2014 8:09am
Naks
AntonioSC wrote:
Hi Fish:
Regards,
Antonio
Yep, my mechanic used a long drill bit and broke up the internals into small pieces, which then fall out of the other side of the cat --
Post #360060 25th Sep 2014 8:39am
bear100
Bear in mind that it will an MOT failure to not have a cat, that said I will still remove mine Shocked I will replace the cat section at Mot time and again remove it just after!
Thumbs Up
You could easily just bash! the internals out but my luck is not the best and I will end up having a jobs worth mot tester 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #360068 25th Sep 2014 10:21am
K9F
Bear under current rules the tester would never know.....
ZeDefender wrote:
Those with weak stomachs, look away now...
10 minutes and a lot of dust - hopefully not asbestos Shocked
If I can, I'll be testing emissions before and after EGR blanking and cat removal - can probably squeeze some school project out of it for my lazy son Thumbs Up
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  If you go through life with your head in the sand....all people will see is an ar5e!!
Post #360070 25th Sep 2014 10:28am
dgardel
Italy
but the reduced backpressure can shorten the turbo life. Ask to BAS..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #360125 25th Sep 2014 5:43pm
