Home > Maintenance & Modifications > Clear Rear Indicator Lenses
lorenzo90
Hi all,
Newbie question number 2.
I tried a search but didnt get very far.
I plan to change the rear indicators on my Puma 90 when i pick it up. I'll keep it simple and not bother with LED's for possible legailty purposes (and i've read something about relays for some lights?) so i'll just get some standard ones.
Does anyone know the part number for this? I keep seeing ones being sold saying both front and rear indicators are the same, but also some with their own specific part numbers?
XBD100670
XBD500010
Thanks very much Smile
Post #358654 18th Sep 2014 2:27pm
Wipac LED versions and RDX led lights are all E marked thus fully UK and EU legal.
Post #358656 18th Sep 2014 2:42pm
gilarion
If you do not wish to install LED's then don't go for genuine parts, as Wipac are much cheaper, just buy the clear lens as you will already have the bulb holder bit and insert an Orange bulb should cost you about a fiver for all four lenses and bulbs
Post #358657 18th Sep 2014 2:44pm
jimbob7
/\/\/\Orange bulbs and bulb holders have different fitting,the pins are slightly offset,to stop putting the wrong bulb in. Pov.spec,ftw. 2006, 110,TD5.
Post #358740 18th Sep 2014 7:42pm
Clear lenses the cheap way:
Post #369714 5th Nov 2014 1:58pm
munch90
you can get standard pin amber bulbs , cars that have clear lenses from new have amber bulbs with offset pins , but for converting from amber
to clear you need amber standard pin bulb
Post #369790 5th Nov 2014 8:27pm
