![]() | Home > Maintenance & Modifications > Clear Rear Indicator Lenses |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
Wipac LED versions and RDX led lights are all E marked thus fully UK and EU legal.
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5139 ![]() ![]() ![]() |
If you do not wish to install LED's then don't go for genuine parts, as Wipac are much cheaper, just buy the clear lens as you will already have the bulb holder bit and insert an Orange bulb should cost you about a fiver for all four lenses and bulbs
/\/\/\Orange bulbs and bulb holders have different fitting,the pins are slightly offset,to stop putting the wrong bulb in. Pov.spec,ftw. 2006, 110,TD5.
Clear lenses the cheap way:
you can get standard pin amber bulbs , cars that have clear lenses from new have amber bulbs with offset pins , but for converting from amber to clear you need amber standard pin bulb |
