Page 732 of 1395 <123 ... 731732733 ... 139313941395>
Fitted these yesterday:
They've been on my wish list for longer than I care to remember but never got around to getting some.
(Apologies for the photo, it came over cloudy at the time)
Thumbs Up
Post #357216 11th Sep 2014 12:13pm
mk1collector
Bought and fitted a new headlight switch because they wouldn't work last night Big Cry then as they still wouldn't work I found the loose connection that just needed pushing back in Evil or Very Mad Rolling Eyes maybe I should look before buying parts Whistle
Post #357224 11th Sep 2014 12:45pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
fitted jw speaker headlights - bought from www.mobilecentre.co.uk
Post #357247 11th Sep 2014 2:43pm
Terryt
Why when you just get every thing sorted does something else go wrong .........
Crying or Very sad
Post #357396 12th Sep 2014 10:54am
landy andy
Law of sod
Post #357401 12th Sep 2014 11:10am
jimbob7
yeah,for every pound I've spent modding mine I've spent £30 fixing it,lol. Pov.spec,ftw. 2006, 110,TD5.
Post #357414 12th Sep 2014 12:03pm
ericvv
ericvv wrote:
Adjusted my JW Speakers height today. Did it the simple way, park the truck on a level road, walk at least 40m away, and lower my head to see when each of the low beam lamps start to blind me. Then with a screwdriver adjust each of them up or down as required and make sure that both are identical height. Also checked the front fogs to make sure oncoming traffic will have no problems at all from my front lights. Driving tonight confirms beam is high enough, and same time none of the oncoming traffic has signalled me. Thumbs Up
Eric
Completed the lights height correcting today as per above I only did the Speakers low beam two weeks ago. Today I also corrected the level of one of the aux high beam halogen lights which had been pointing a bit too high. Again, did it the simple way, park the truck on level ground in front of a wall and check if both the beams of the aux lights are the same, if not as was the case here, it just takes a screwdriver to correct the aux lamps up or down.
Oh, and before that, ran the SVX through the car wash tunnel and properly towel dried it thereafter, and let it further dry out in todays sunny breezy weather. Mr. Green
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #357469 12th Sep 2014 5:22pm
Venomator
Thumbs Up
SNAP... Thumbs Up
Fitted same today, except for the side intake, as I already have a Snorkel fitted... Whistle
Great quality from Flatdoguk.com... Bow down
And also like the replacement Torx screws and driver, nice touch... Mr. Green
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #357502 12th Sep 2014 7:36pm
Trailer lighting issues today, notice the lights going nutty today.
Defender it's self is fine but trailer attached it goes odd.
Although fiddled about and it worked fine once I abandoned my trip tonight to get stuff.
My guess is poor contact, shall have to clean the plug up Defender side and check the rear fot corrosion.
Both are high in my suspicion as suspects.
Neutral
Post #357505 12th Sep 2014 7:45pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
Big update for me Cool
Monday fitted led fog lights and wired them to landrover aux 2 switch, also fitted and wired up a 44" led lightbar to the roof and fitted a led work light for my winch
yesterday i removed the genuine side steps as they resembled swiss cheese, then set about removing the std sills ( not fun) as they havent being touched in 10 years. after adding to the swear jar countless times. Once this was done i fitted some tree sliders
Today i fitted a new xs cubby box from matt, and discovered td5's have a larger cubby box than pumas, also i fitted a galv transmission guard, extended the fuel tank breather 2004 TD5 Defender 90 xs station wagon
Post #357522 12th Sep 2014 8:37pm
Tiger
Fitted a relay to the lights. (although my existing lights had 14v across them so doubt I'll see a light upgrade but at least the switch may not burn out)
Did a few more of the SS bolts
Replaced the Screen hinge gasket to cure a leak
Very Happy
Post #357619 13th Sep 2014 3:57pm
Josh K
United Kingdom 2007 Defender 90 Puma 2.4 HT Orkney Grey
What tree sliders did you go for? 2007 (57) Defender 90 (Sold)
Looking for another to replace it.
The road less travelled.... is a muddy one!
Post #357625 13th Sep 2014 4:21pm
Romadog
Went shopping for house extension stuff.
Had over 200 quarry tiles in the back and 3 x carpet sample packs !
For the first time my heavy duty twin coil suspension had some work to do Thumbs Up
Post #357647 13th Sep 2014 7:15pm
OldhamLandy
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Santorini Black
Fitted a Nakatanenga rear door stay - no more door hitting me in the backside every time I park on an incline Thumbs Up
Also fitted an Entreq Snow Cowl which looks the dogs nads Bow down 2016 Defender 90xs SW - Santorini Black with Silver Pack
2014 Defender 90xs SW - Corris Grey with Santorini Black Roof
Post #357652 13th Sep 2014 8:07pm
johnszs
i went for the safari equip ones as they are galvanised before powdercoated 2004 TD5 Defender 90 xs station wagon
Post #357741 14th Sep 2014 11:30am
