| g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967
treat it to a brand new turners Amc head
my youtube channel |
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
Drove home with a very leaky main seal and might have picked up a puncture.
which seal is that? My 109 thread
Engine Rear Main Crankshaft Seal.
Dropped nearly half a litre on the way to and from work today. Not happy..... |
youve just had clutch done havent you? did they touch seal? My 109 thread
back in the freelander then
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939
That's the same seal that I had done too, mine was leaking before I went too.
You've got to smile it's why we like our leaky troublesome Landy's. |
Yep, which isn't the worst vehicle in the world. But its not mine
I know! its so weird that they both need similar treatment within days of each other. Hopefully your fix will last longer than mine. I do love my troublesome truck, but I wish sometimes she would just behave. That said, she has given me 6.5 thousand miles since the last issue which was a leaking hub assembly in April(?) so its not all bad. |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986
Click image to enlarge Covered tailgate with rubber cp, so dog does not slide off it. Andy |
| kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403
Thats tidy Andy. How did you get it tight over the ridges on the inside of the tailgate? Have you eddged it with ali angle all the way round?
Just used a pu sealer to stick it. Like tiger seal stuff, and a piece of ally angle top and bottom. I was getting concerned because when he jumps in he slides and legs go down gap between tailgate an crossmember. Sorted now.
Be careful of the support cables too, we had those on a Navara we used to have and if they jump or slip off the side they could so easily break their leg.
We always used to take them in and out on a lead anyway for safety's sake. I guess it depends on the trust you have and the dogs mentality if they are calm and sensible or a mad hatter. |
| sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455
Steve I was going to post exactly the same thing
When we Let ours out sometimes they charge off to the side and I cringe every time, same when jumping back in. I've got the SVX rubber rear mat on mine and a fold out flap to bridge the gap between the crossmember but thinking of fold up sides to encase the triangle It's good to be back from the dark side DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
That'd be a good idea Lee, as you say make me cringe too you can just see it could be an accident waiting to happen.
