![]() | Home > Maintenance & Modifications > ACF50 |
993porky Member Since: 02 May 2011 Location: sunderland Posts: 171 ![]() ![]() ![]() |
ACF50
What is it? |
http://www.acf-50.co.uk/ Pov.spec,ftw. 2006, 110,TD5.
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
Best to do a web search, but I can confirm it is easy to use and appears to work DEFENDER 90 TDCI XS,
Cheers for quick replies
I am using ACF-50 to spray the cilinder area of my door hinges as there has been some rust forming from the inside. Two questions about this product.
In the ACF-50 link provided by jimbob I read that an annual application would be sufficient. Sounds long to me, presume better to repeat more frequently? And somewhere in the motorcycle application section it says that it is not damaging paint. I try to wipe away any rundowns quickly, but is it correct that if I miss some, this product is indeed entirely harmless to paint? Tks, Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5991 ![]() ![]() |
I've got it on my paintwork without any issue. Still some all over the back of the truck now.
Andy |
no problem with my paint and does appear to protect for about 12 months DEFENDER 90 TDCI XS,
I think corrosion block is better in some places , bit thicker , lasts longer and is made by the same people , but harder to get
you can get a corrosion block grease as well , good for re fitting bolts with I bit on the threads , grease is easy to get on fleabay etc |
Columbus Member Since: 23 Mar 2014 Location: United Kingdom Posts: 32 ![]() ![]() ![]() |
I've used it for years on my bikes and cars. It doesn't replace regular maintenance but it does what it says on the tin. It's best applied in mist form using a spray gun which I don't have so I use an Autoglym sprayer which you can pump up and sit it in boiling water for a few minutes to thin it out a bit. Just keep clear of the brake discs and glass.
Usually get it from here http://www.nippynormans.com/products/acf-50 |
adamatdraycott Member Since: 11 Nov 2013 Location: Midlands Posts: 299 ![]() ![]() ![]() |
I only use acf50 on fasteners and external areas like the bumper and cross member... All of which don't require a spray gun
Underneath and all cavities are coated with dinitrol. |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
I had my 110 Dinitroled by Zagato a few weeks back and I have been using ACF50 as directed in his corrosion prevention guide.
I tend use it after every third or fourth wash in the areas where I had corrosion problems in my previous Td5. Doesn't mark the paint but as Adamatdraycott says it has an unusual tacky feel to it. Cheers John 2014 110 2.2TDCi XS Station wagon - GONE 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - GONE 2024 110 D250 X-Dynamic HSE |
