Home > Maintenance & Modifications > ACF50
993porky
United Kingdom 2002 Defender 90 Td5 HT Baltic Blue
ACF50
ACF50
What is it?
Post #320664 31st Mar 2014 10:03pm
jimbob7
http://www.acf-50.co.uk/ Pov.spec,ftw. 2006, 110,TD5.
Post #320665 31st Mar 2014 10:05pm
LR90XS2011
Best to do a web search, but I can confirm it is easy to use and appears to work DEFENDER 90 TDCI XS,
Post #320666 31st Mar 2014 10:05pm
993porky
Cheers for quick replies Thumbs Up
Post #320667 31st Mar 2014 10:10pm
ericvv
I am using ACF-50 to spray the cilinder area of my door hinges as there has been some rust forming from the inside. Two questions about this product.
In the ACF-50 link provided by jimbob I read that an annual application would be sufficient. Sounds long to me, presume better to repeat more frequently?
And somewhere in the motorcycle application section it says that it is not damaging paint. I try to wipe away any rundowns quickly, but is it correct that if I miss some, this product is indeed entirely harmless to paint?
Tks, Eric You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #354663 31st Aug 2014 6:22am
landy andy
I've got it on my paintwork without any issue. Still some all over the back of the truck now.
Andy
Post #354666 31st Aug 2014 7:06am
LR90XS2011
no problem with my paint and does appear to protect for about 12 months DEFENDER 90 TDCI XS,
Post #354670 31st Aug 2014 7:45am
adamatdraycott
United Kingdom 2014 Defender 90 Puma 2.2 SW Corris Grey
I apply every couple of months... Hoping to build up some layers.
If you leave it on your paint work it seems to leave an oily mark, which is very much reduced when next washed
When you have applied it to the rear cross member and front bumper it has a strange tacky feel when you wipe over it with your sponge or wash mitt.
Once you know the areas in which it's needed, you can do the whole car in maybe 20mins
I tend to use a small artists paintbrush to apply to bolt heads, rear cappings, and around hinges. A rag is perfect for bigger areas.
Post #354676 31st Aug 2014 8:40am
munch90
I think corrosion block is better in some places , bit thicker , lasts longer and is made by the same people , but harder to get
you can get a corrosion block grease as well , good for re fitting bolts with I bit on the threads , grease is easy to get on fleabay etc
Post #354677 31st Aug 2014 8:42am
Columbus
Scotland 2005 Defender 110 Td5 DCPU Alveston Red
I've used it for years on my bikes and cars. It doesn't replace regular maintenance but it does what it says on the tin. It's best applied in mist form using a spray gun which I don't have so I use an Autoglym sprayer which you can pump up and sit it in boiling water for a few minutes to thin it out a bit. Just keep clear of the brake discs and glass.
Usually get it from here http://www.nippynormans.com/products/acf-50
Post #354727 31st Aug 2014 1:27pm
adamatdraycott
I only use acf50 on fasteners and external areas like the bumper and cross member... All of which don't require a spray gun
Underneath and all cavities are coated with dinitrol.
Post #354729 31st Aug 2014 1:37pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
I had my 110 Dinitroled by Zagato a few weeks back and I have been using ACF50 as directed in his corrosion prevention guide.
I tend use it after every third or fourth wash in the areas where I had corrosion problems in my previous Td5.
Doesn't mark the paint but as Adamatdraycott says it has an unusual tacky feel to it.
John 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #354744 31st Aug 2014 3:15pm
