![]() | Home > Puma (Tdci) > P1103 fault Code |
| lornick Member Since: 02 Sep 2009 Location: Aberdeenshire Posts: 32
Hi Guys
Hooked the caravan onto the back of the 110 today (2009 utility) and after a long pull up an incline on a dual carrigeway. got a MIL on the dashboard. Have a scanguage 2 which produced the fault code P 1103 - which was fine. However, the scanguage will not let me reset/clear the code which is strange. Any ideas? Truck was just serviced last week, so everything is as it should be (i hope....) Wouldn't normally be bothered, but I'm pulling the van from Aberdeen down to Silverstone after work today, and would prefer not to do the trip on the back of a RAC recovery truck if at all possible! Thanks in anticipation.......[/b] |
| cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336
Have a look here:
http://www.defender2.net/forum/post69553.html Might be worth picking up a spare MAF en route for peace of mind |
Thanks for that - good advice.
Just rang the local stealer who happens to have one in stock - but is wanting £119 for it!! I've seen other posts with them around the £30 mark.....think I'll keep looking. cheers |
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
I just cleaned my MAF sensor (done it every 25,000 km) - massive improvement. You must use proper MAF cleaner though (not carb or MAP etc.) or you can strip the coating. See
http://www.mafcleaning.co.uk/ Worth a try before binning it perhaps? Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Thanks for that - i'll pick a can up on the way down the road.
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
P1103 is a 'nuisance code' that will invariably reset after a few driving cycles. If it persists then look at a MAF but at your stage I wouldn't be overly concerned. Numerous threads about it if you do a search under 'P1103.'
| dilukabey Member Since: 17 May 2011 Location: Sri Lanka Posts: 173
I get this code P1103 when cruising on motorways perhaps with high acceleration. I have closed my egr mechanically ie. Closed inlet and outlet of egr. Don't know something to do with it. When this occur, I simply use the scanguage. I always clear the code when dash lights illuminated at ignition but with engine shut downed. I noticed when engine is on the scanguage does not response to clear p1103.
| Josh K Member Since: 01 Nov 2013 Location: Herefordshire Posts: 266
http://www.defender2.net/forum/topic28920.html
A previous post on clearing fault codes with a Scangauge 2 2007 (57) Defender 90 (Sold) Looking for another to replace it. The road less travelled.... is a muddy one! |
