Home > Puma (Tdci) > Puma Clutch Death Rattle Again
Page 2 of 7 <1234567>
Higgers
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Firenze Red
Bob,
Is making contact with the LR Technical team something which you instigate or the dealer??
Do you have a number.
Thanks
Ian
Post #35388 30th Jun 2010 1:16pm
bob neville
Ian
The dealer instigates contact with LR tech support I'm afraid.
I will see if the dealer will divulge any contact details next time I speak with them.
You cound try LR customer support, they have been very helpful the last couple of times I have spoken to them.
Bob
Post #35389 30th Jun 2010 2:46pm
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
bob neville wrote:
the clutch bites at about 1/4" off the floor. It has had a new slave cylinder and new master cylinder plus revised pipework. After the new master was fitted last night everything appeared to be fixed, the same as at the weekend. However, after being parked overnight the clutch bite position returned to 1/4" off the floor. The dealer agrees that the vehicle is undriveable and the problem is now with the LR technical team.
Bob
Exactly the same thing happened to me - it spent 2 days in the workshop with them trying to bleed it and stuff, then they started saying they wanted to get permission from LR to remove the box and clutch to see what was wrong. The next day a GOOD mechanic came back to work after 3 days holiday and quietly stated that it just needs some or other thing adjusted or set....(i don't know what it was, i was too relieved to even bother)
Perfect now, nice strong clutch at last (i hope it lasts!)
Cheers, www.ralton.co.za
Post #35390 30th Jun 2010 2:53pm
bob neville
Cheers,
Any chance you could find out what it was ?
It would be much appreciated - I am getting fed up with FL2's.
Bob
Post #35391 30th Jun 2010 3:16pm
mse
I have the contact details for the technical team (family Whistle ) but there is no point you contacting them as they a)wont talk to you b) wont act if they do and c) cant do anything anyway.
It has to come through the dealer - warranty control the parts and versions and again there is a strict process they will not deviate from.
As for the noise, yes same deal - 30 mile drive on sunday in the heat. Pulled into the car park, low speed (with rev's) rattle, clatter etc. The noise seems to be when worked hard and or hot, followed by low speed work. The difficult selection seems to be when cold. Probably one fault leading to the other.
Version 2 of the clutch (the version fitted to the current production run) is the official fix should "customer raise concern" version 3 is restricted to proved and identified fault of version 2 (2nd fit) eg if you have version 2 you will get it again before they consider the 3 version of the clutch. I have been told that from 2 sources now. Mike
Post #35393 30th Jun 2010 5:50pm
MK
back from the dealer. The clutch (v2) plate had an uneven wear, i.e. On both sides the wear suggest there is contact on the outer and inner edges of the plate. Shocked
Anyway the plate look quite sh11ty compared to a Td5, which has less torque. Puma 110" SW
Post #35394 30th Jun 2010 5:52pm
Allan
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
Thanks for that imfo. Mike. Will see what happens next week when the pull it down.
Allan
Post #35406 30th Jun 2010 10:53pm
bob neville
Thanks for that Mike.
As I am on number two of version two maybe my dealer will try the restricted version today.
Have you got your vehicle back yet - if so, has the problem been resolved ?
Bob
Post #35412 1st Jul 2010 8:16am
MK
Those who had their clutch replaced, anybody had the chance to look how the used disc weared? Puma 110" SW
Post #35471 2nd Jul 2010 11:46am
bob neville
Latest guess from LR tehnical support Laughing
They think the clutch plates on the newly fitted clutch are to thin Shocked
Problem is my dealer was supposed to have a new clutch delivered this morning but it didn't turn up. They have been told to compare the two.
This begs the question, what if there are a faulty batch of clutches and they are both from the same batch ?
Do LR have no technical specs they can compare against ?
The mechanic working on my car can now remove the gearbox blindfold quicker than an F1 tyre stop !
Bob
Post #35488 2nd Jul 2010 3:25pm
mse
Bob
Oh Joy... Mike
Post #35489 2nd Jul 2010 3:32pm
MK
Bob
please keep us posted Puma 110" SW
Post #35491 2nd Jul 2010 3:47pm
Eduardo
Grrrrrr Evil or Very Mad
I can believe that, so they dont have any idea about what kind of pieces have each car?
Please keep us posted... Eduardo
Post #35493 2nd Jul 2010 5:30pm
bob neville
Correct !
Also no QA whan parts arrive from the supplier by the looks of it , otherwise they would have been rejected.
I can't wait to see what Saturday brings !
Two weeks and counting to replace a clutch - time for more LR compensation me thinks Laughing
I have to say, my dealer has been excellent throughout the whole episode - and we can have a laugh about the problem - better than crying I suppose.
Bob
Post #35494 2nd Jul 2010 5:40pm
MK
IIUC there is faulty batch for v2 plate? Big Cry Puma 110" SW
Post #35495 2nd Jul 2010 5:48pm
