|  | Home > Technical > Defender 90 (2004) TD5 - Front Hub |
| Tank Member Since: 25 Jul 2014 Location: Fife Posts: 444      | What size bolt ? | ||
|  22nd Aug 2014 6:04pm |
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443      | You can use one of the hub flange bolts which although aren't quite the correct thread, when screwed in by hand give you enough purchase to pull on the shaft. | ||
|  22nd Aug 2014 6:32pm |
| Tank Member Since: 25 Jul 2014 Location: Fife Posts: 444      | All done.
 Bit of a faff but done. Had to take the hub back off and when I did the staked nut stripped some of the threads on the stub axle ! It's all gone back on ok so lets wait and see how it goes . Enjoyed doing it, doing the bearings was fun. Cheers and thanks ever so much for all the advice, very much appreciated. Great forum really helpful Cheers Duncan | ||
|  22nd Aug 2014 9:04pm |
| Posting Rules
