Home > In Car Electronics > Problems wiring my blue sea relay / dual odyssey 1500 batts.
Page 4 of 4 <1234
Riyo
Scotland 2012 Defender 110 Puma 2.2 SW Santorini Black
i measured the resistance between the 2 positive terminals with the car turned off and my meter (£10 cheapo one) reads 150ohm... i was expecting to see something much higher than that as the battery positives should be isolated..
Is my switch in the right position?
Post #352274 18th Aug 2014 11:39am
munch90
voltages look ok
long shot by is there a fan that's runs on the fridge that could be setting the volumetric sensor off
sorry don't know about the switch
Post #352275 18th Aug 2014 11:40am
Riyo
there is a fan i think on the fridge and that thought did cross my mind but many have fitted here without issue i believe.
If the battery voltage does drop does the alarm/BBUS go off? if so any idea what this voltage might be?
Post #352276 18th Aug 2014 11:43am
munch90
not 100% but think alarm should go off if disconnected not battery going flat , what if you take the fridge out ?
Post #352281 18th Aug 2014 12:07pm
ZeDefender
I'm assuming you still have the alarm coming off the starter battery. If the batteries are coupled, are you sure that the fridge etc. coming on doesn't cause a temporary voltage dip in the starter battery which triggers the alarm? Or/and, when set to automatic, the BlueSea will uncouple the batteries when the overall voltage (e.g. caused by the fridge drops). This will also muck about with the voltage of the starter. I can't remember exactly what happens when but if you haven't done so, try uncoupling the batteries.
p.s. Can't remember but don't you disconnect the batteries with the switch to the right? Tell someone you love them today because life is short.
Post #352282 18th Aug 2014 12:30pm
Riyo
Zedefender,
yes the alarm comes off the starter battery,
the thing is the 2 batteries should be isolated so even if the fridge is misbehaving it should have zero effect on the starter battery / alarm.. i may try physically decoupling the batteries to see if that changes anything..still its not like my battery voltages are low and the fridge doesnt really draw much current so the fridge dipping the battery voltages below whatever threshold for triggering the alarm seems unlikely to me.
Post #352292 18th Aug 2014 1:33pm
ZeDefender
It is a long shot... Tell someone you love them today because life is short.
Post #352308 18th Aug 2014 2:38pm
Page 4 of 4 <1234
