Home > Maintenance & Modifications > Door studs
gavinpm
England 2006 Defender 90 Td5 SW Cairns Blue
Door studs
Gents
Can anyone help with the name and part number of these studs shown in the diagram
Thanks
Gavin
Post #349611 5th Aug 2014 9:41am
Martin
Site Admin
Plastic Rivet
MWC9918PMA - black
MWC9918LCS - pale grey
MWC9918LOY - dark grey  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #349617 5th Aug 2014 10:34am
gavinpm
Brilliant - thank you Martin
Post #349621 5th Aug 2014 10:49am
gavinpm
Just looked at a photo of these on line - how are they actually fitted ?
Thanks
Gavin
Post #349628 5th Aug 2014 11:57am
Martin
Site Admin
Hi Gavin, are they missing on yours or some other problem?
You push the bit of the rivet with the legs through the door card into the door frame (requires a wiggle, of the rivet).
Then push the pin into (but not through) the rivet to lock the legs in place.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #349629 5th Aug 2014 11:59am
KarlMD
United Kingdom 2013 Defender 90 Puma 2.2 HT Corris Grey
Door Studs
There is a small dowel in the centre that you need to push through, be careful not to lose it. When you re-fit them, you just push the dowel back in to spread the clip out.
Post #349630 5th Aug 2014 12:02pm
gavinpm
That's right Martin they were missing from the door.
Thanks gents - it wasn't clear from the photo that those pins could be pushed through the rivet head.
Gavin
Post #349637 5th Aug 2014 12:43pm
