![]() | Home > Maintenance & Modifications > Door studs |
gavinpm Member Since: 19 Oct 2012 Location: Wiltshire Posts: 117 ![]() ![]() ![]() |
Gents
Can anyone help with the name and part number of these studs shown in the diagram Thanks Gavin ![]() |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6705 ![]() ![]() ![]() |
Plastic Rivet
MWC9918PMA - black MWC9918LCS - pale grey MWC9918LOY - dark grey ![]() ![]() |
Brilliant - thank you Martin
Just looked at a photo of these on line - how are they actually fitted ?
Thanks Gavin |
Hi Gavin, are they missing on yours or some other problem?
You push the bit of the rivet with the legs through the door card into the door frame (requires a wiggle, of the rivet). Then push the pin into (but not through) the rivet to lock the legs in place. ![]() ![]() Last edited by Martin on 5th Aug 2014 12:03pm. Edited 1 time in total |
KarlMD Member Since: 26 Sep 2013 Location: Staffordshire Posts: 36 ![]() ![]() ![]() |
There is a small dowel in the centre that you need to push through, be careful not to lose it. When you re-fit them, you just push the dowel back in to spread the clip out.
