![]() | Home > Technical > 2.2 oil usage |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3499 ![]() ![]() ![]() |
Mine didn't move a mm in 8500 miles 1951 80" S1 2.0
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
Mine has done just under 10k doesn't seem to have used any oil.
Where was the level on the dipstick when you picked it up? |
psimpson7 Member Since: 20 Nov 2013 Location: Gold Coast, Qld. Posts: 221 ![]() ![]() ![]() |
Thanks. Pretty sure it was dead on full parked at the same point on the drive. Engine had been off for a few hours both times.
No visible leaks. 2001 90 HT 6.0LS/6spdAuto. 2003 90 td5 soft top. 2014 90 XS SW 2.2. |
Booked in at the dealer on Wednesday. Will see what they say. 2001 90 HT 6.0LS/6spdAuto.
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 ![]() ![]() |
Hi Pickles, My 2013MY 110 Utility used about 1/4 of the oil level on the dipstick over the first 6000miles (I then changed the oil myself) and since then has used no oil between 6000 miles services (Currently on 16000 miles).... I would expect this is a normal amount of usage with a new motor?...
Cheers Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2674 ![]() ![]() ![]() |
Those modern engines should not be using any oil whatsoever.
You should have it seen to asap. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
It has a leak... Its from somewhere on the passenger (LH) side of the engine above the PS pump.
Dealer has cleaned it up, refilled oil and wants it back in 1000k's 2001 90 HT 6.0LS/6spdAuto. 2003 90 td5 soft top. 2014 90 XS SW 2.2. |
glpinxit Member Since: 31 Jul 2010 Location: rural Somerset Posts: 159 ![]() ![]() |
When I picked mine up they told me the new engine will use a little oil and gave me 1 litre with a natty zip up bottle cover. Too early to say how it is going. Cheers, Guy.
Odd that the 2.2 is expected to use oil but not the 2.4?
I've now done close to 56,000km and not a single drop of oil used ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
