Home > Technical > 2.2 oil usage
psimpson7
Australia 2014 Defender 90 Puma 2.2 XS CSW Loire Blue
2.2 oil usage
Just a quick question out of interest.
I have a 2014 2.2 90 which has now done 6000km.
The service interval over here is 20000km.
I checked the levels today and the oil level is about 2/3rds of the way down the allowable range on the dipstick.
At that rate it will only make around 9000 k's before its low on oil, which is no where near the official service interval (not that I would wait until 20000 anyway!)
What sort of oil usage are people seeing with the 2.2's?
cheers
Pete 2001 90 HT 6.0LS/6spdAuto.
2003 90 td5 soft top.
2014 90 XS SW 2.2.
Post #346397 20th Jul 2014 7:54am
familymad
Mine didn't move a mm in 8500 miles 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #346409 20th Jul 2014 9:23am
RobKeay
Mine has done just under 10k doesn't seem to have used any oil.
Where was the level on the dipstick when you picked it up?
Post #346472 20th Jul 2014 12:42pm
psimpson7
Thanks. Pretty sure it was dead on full parked at the same point on the drive. Engine had been off for a few hours both times.
No visible leaks. 2001 90 HT 6.0LS/6spdAuto.
2014 90 XS SW 2.2.
Post #346480 20th Jul 2014 1:00pm
psimpson7
Booked in at the dealer on Wednesday. Will see what they say. 2001 90 HT 6.0LS/6spdAuto.
2014 90 XS SW 2.2.
Post #346643 21st Jul 2014 3:39am
Morepower
New Zealand
Hi Pickles, My 2013MY 110 Utility used about 1/4 of the oil level on the dipstick over the first 6000miles (I then changed the oil myself) and since then has used no oil between 6000 miles services (Currently on 16000 miles).... I would expect this is a normal amount of usage with a new motor?...
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #347497 25th Jul 2014 8:00am
Naks
Those modern engines should not be using any oil whatsoever.
You should have it seen to asap. --
Post #347503 25th Jul 2014 9:09am
psimpson7
It has a leak... Its from somewhere on the passenger (LH) side of the engine above the PS pump.
Dealer has cleaned it up, refilled oil and wants it back in 1000k's 2001 90 HT 6.0LS/6spdAuto.
2014 90 XS SW 2.2.
Post #347505 25th Jul 2014 9:23am
glpinxit
When I picked mine up they told me the new engine will use a little oil and gave me 1 litre with a natty zip up bottle cover. Too early to say how it is going. Cheers, Guy.
Post #347636 25th Jul 2014 11:15pm
Naks
Odd that the 2.2 is expected to use oil but not the 2.4?
I've now done close to 56,000km and not a single drop of oil used Thumbs Up --
Post #347666 26th Jul 2014 8:52am
