Home > Maintenance & Modifications > TACK Rack now finished
TACK
Back from the powder coaters, apart from finding some black bolts and washers shes finished Bow down
1 shelf
2 shelf
And the A4?map holder too Mr. Green
Post #34552 16th Jun 2010 11:14pm
K9F
Looking good Tack! Thumbs Up
Also like the blue rodent drinking bowl you've fitted to the right of your cubby box! Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #34553 16th Jun 2010 11:28pm
TACK
thanks mate Mr. Green
the roddent goes into the cage and its connected by the cable to the left of the cage to a power locking device Rolling with laughter Rolling with laughter
I knew either you or fekete would comment after I saw the 'other' items in my picture Laughing Rolling with laughter Rolling with laughter
Post #34554 16th Jun 2010 11:32pm
K9F
Does look a great job! Have you taken it for a spin to make sure it doesn't rattle or have you factored that in to the build so it doesn't? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #34555 16th Jun 2010 11:38pm
TACK
Does not rattle with normal driving to and from work etc. Did some lanes in wales inc Happy valley with no shelves but with the side baskets installed and no rattles. had there been rattles then I would have used some old bike innertube between metal to metal or a rubber gasket of some sort. The shelves are not 'fitted' i think this is the case with the Mantec one, thats why CIBIT 'I think' uses ratched straps. the shelves will move eventually off road, so I will either use short bungies or small ratchet straps from the original D tie downs up to the shelf. Thats for the time being. I have already factored in a way to bolt the shelves to the basket frame work, but this would mean unbolting each time, but I have the option Very Happy
First proper trial run this weekend at the potnoddle challenge Mr. Green
Post #34556 16th Jun 2010 11:50pm
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
That looks really good Tack.
Just a quick question, what is the steel that you sed called? I have been looking for something similar and have had no luck.
Ben 2002 Defender 110 DC
Post #34564 17th Jun 2010 8:53am
TACK
Cheers Ben.
This is the comapny I got it from. I also found it hard to find then found this on my doorstep Rolling Eyes
the products they do is limitless, very friendly, very professional set up and top products. Thumbs Up
http://www.fhbrundle.co.uk/groups/03P__Perforated_Metal
TACK
Post #34590 17th Jun 2010 1:17pm
ben_j85jty
Ha!
Brundles - I have been there more times than I can think of. I thought they just did railing supplies - right under the nose indeed
Tack 2002 Defender 110 DC
Post #34594 17th Jun 2010 3:38pm
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
A day later and that's still making me laugh. Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #34601 17th Jun 2010 8:13pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Looks good Thumbs Up but whats with the map holder!!! time you bought a laptop and memory map or Touratech QV
Post #34727 20th Jun 2010 8:47pm
Did you make these, or buy them?
If "made", was it just a project, or (judging by your username) is this your business?
how much are they, if they are for the open market?
Post #34791 21st Jun 2010 6:30pm
RLD
hey tack nice to see you Thumbs Up RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #34792 21st Jun 2010 6:35pm
discocuzzy
Jim...its a home job and a very good one by the looks of it, well done Tony Thumbs Up You cannot teach stupid people to do clever things
Post #34795 21st Jun 2010 7:23pm
TACK
As discocuzzy said Thumbs Up a home job, not in the business, just a hobbiest. Was looking at purchasing the Mantec one which I believe is now discontinued but that requires drilling into the arches to fit and circa �300, which I have now saved and I was going to put to a ram mount but I made a map holder which saved me a few more quid Rolling with laughter not considered putting it to open market Jim due to the time it takes with the home set up I have. If there were a few people intrested in the Map holder I could do half a dozen. I used mine all weekend and it was spot on Mr. Green
Sonic, after seeing Higgers navigating on his PC at the weekend I am 100% going to get a set up, waiting to see an IPAD in action first. Thumbs Up
Ray, nice to meet you to, I can now say I have felt the warmth of you custom in person Mr. Green Thumbs Up
Post #34824 21st Jun 2010 11:26pm
Well, you did an A1 job on that lot!
I'd be up for a map holder if/when you do any more Thumbs Up
Post #34828 22nd Jun 2010 8:13am
