![]() | Home > Maintenance & Modifications > TACK Rack now finished |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 ![]() ![]() |
Back from the powder coaters, apart from finding some black bolts and washers shes finished
![]() 1 shelf ![]() 2 shelf ![]() ![]() And the A4?map holder too ![]() ![]() |
Looking good Tack!
![]() Also like the blue rodent drinking bowl you've fitted to the right of your cubby box! ![]() Treat every day as if it is your last....one day you will be right!! |
thanks mate
![]() the roddent goes into the cage and its connected by the cable to the left of the cage to a power locking device ![]() ![]() I knew either you or fekete would comment after I saw the 'other' items in my picture ![]() ![]() ![]() |
Does look a great job! Have you taken it for a spin to make sure it doesn't rattle or have you factored that in to the build so it doesn't? If you go through life with your head in the sand....all people will see is an ar5e!!
Does not rattle with normal driving to and from work etc. Did some lanes in wales inc Happy valley with no shelves but with the side baskets installed and no rattles. had there been rattles then I would have used some old bike innertube between metal to metal or a rubber gasket of some sort. The shelves are not 'fitted' i think this is the case with the Mantec one, thats why CIBIT 'I think' uses ratched straps. the shelves will move eventually off road, so I will either use short bungies or small ratchet straps from the original D tie downs up to the shelf. Thats for the time being. I have already factored in a way to bolt the shelves to the basket frame work, but this would mean unbolting each time, but I have the option
![]() First proper trial run this weekend at the potnoddle challenge ![]() |
ben_j85jty Member Since: 03 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 ![]() ![]() ![]() |
That looks really good Tack.
Just a quick question, what is the steel that you sed called? I have been looking for something similar and have had no luck. Cheers Ben 2002 Defender 110 DC |
Cheers Ben.
This is the comapny I got it from. I also found it hard to find then found this on my doorstep ![]() the products they do is limitless, very friendly, very professional set up and top products. ![]() http://www.fhbrundle.co.uk/groups/03P__Perforated_Metal TACK |
Ha!
Brundles - I have been there more times than I can think of. I thought they just did railing supplies - right under the nose indeed Cheers Tack 2002 Defender 110 DC |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
Looks good
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6188 ![]() ![]() ![]() |
Did you make these, or buy them?
If "made", was it just a project, or (judging by your username) is this your business? how much are they, if they are for the open market? |
RLD Member Since: 29 Jun 2007 Location: Lancs Posts: 858 ![]() ![]() |
hey tack nice to see you
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 ![]() ![]() |
Jim...its a home job and a very good one by the looks of it, well done Tony
As discocuzzy said
![]() ![]() ![]() Sonic, after seeing Higgers navigating on his PC at the weekend I am 100% going to get a set up, waiting to see an IPAD in action first. ![]() Ray, nice to meet you to, I can now say I have felt the warmth of you custom in person ![]() ![]() |
Well, you did an A1 job on that lot!
I'd be up for a map holder if/when you do any more ![]() |
