adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1388 ![]() ![]() ![]() |
pull started the wifes Hossbox....bloody starter motors... Putting Dreams on Drives at JLR Solihull..
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5991 ![]() ![]() ![]() |
Fixed the rear hub bolts that had sheared off and replaced the passenger side rear brake pads. Drivers side tomorrow if its not raining. 1999 Defender TD5 110
Dale Member Since: 14 Jul 2014 Location: Bristol Posts: 79 ![]() ![]() ![]() |
Went to Maplin for a 12v aux socket and fitted it
![]() Click image to enlarge While in Maplin also spotted this ![]() Click image to enlarge |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20879 ![]() ![]() |
It's got Killer style alloys on it.
Rosso_NI Member Since: 09 May 2014 Location: NI Posts: 275 ![]() ![]() ![]() |
Got rid of some bad pitting on valve seats in preparation for grinding in new valves,
![]() Click image to enlarge Also in anticipation of starting to put my V8 back together thought i would make inlet manifold a bit more appealing ![]() Click image to enlarge |
Finished replacing the rear brake pads (started it yesterday but rain stopped play) 1999 Defender TD5 110
Nobby Member Since: 09 Aug 2012 Location: Wiltshire Posts: 444 ![]() ![]() ![]() |
Took mine for a drive, yesterday to the CLA Gamefair to see what the new wheels and tyres felt....sounded like. Pleased with the look and very happy with the noise and feedback from the rubber. _______________________________
Puma Defender 90 |
Well yesterday...picked up (another) galvanised chassis
![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Cleaned up the starter motor solenoid contacts but it made no difference so ordered a repair kit.
The way it goes I suppose, if the contacts have eroded too far then no amount of cleaning is going to revive them. When I was having major problems with a leaking FPR the cleaning trick worked for me a few times, it took some time for the remaining oil washed crud to stop getting in to the contacts, I began to get quite adept at sitting underneath and whipping the solonoid out and cleaning it up, only once did I leave power connected, when you arc the spring against the barrel of the solonoid housing after liberally squirting contact cleaner in there it produces a great way to lose your eyebrows, whatever hair you've got left on top and causes onlookers to run for fire extinguishers!
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 ![]() ![]() ![]() |
Sorry for not getting back on this but i have been doing someone else's shift at work and sleep has been virtually none existant but i am on my normal shift now so everythings ok again ![]() anyway 90 ran ok to angelsey and back but did use a bit more juice than i was expecting but think I may have sorted part of the reason but will find out better after we have been to billing this Saturday. anyway started off at treaudder bay but lost a lot of tackle due to snagging on rocks then later drove to hollyhead breakwater and spent the last few hours there but didn't catch anything but are planning a camping / fishing trip there next month all being well ![]() will post pic's later ![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
And here are a few pic's
![]() ![]() ![]() ![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
/\/\/\What make is it?? Pov.spec,ftw. 2006, 110,TD5.
