Home > Td5 > Fuel Pipes Wrong - Damage? TD5 |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
Don't know about the fuel pipes, but I had a period of poor starting on my TD5 and it turned out to be a loose connection on one of the relays under the drivers seat.
I closed up the spade connectors on the relay and all has been well for several months. Hope that helps. Cheers Simon |
13th Jul 2014 8:53am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6050 |
When I built the project90-3, during the numerous head changes and bodging ahem, modifying the fuel cooler to work with a mix mach of 10P and 15P fuel pipes, I ended up with the flow and return the wrong way round on the engine.
It ran fine the "wrong" way, and seemed no different once I corrected it. Note: I never drove it as it was during the build, so the engine was only on tickover on the drive (and the odd revving of it), so the fuel pressure regulator may/may-not have come into play; I'm not sure how it works in relation to the running of the engine, and/or if it works when fed fuel "backwards", but as I say, mine ran fine afterwards anyway. So if you'rs didn't even start, then I can't see any damage would have been done. |
13th Jul 2014 9:52am |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 |
A quick tip, un screw the water separator from the filter and prime the pump to see if fuel comes out. If it doesn't, unscrew the connections on your OLD filter housing and make sure the new ones are the same. There is a little gauze type plunger in one of the connectors and I have had brand new genuine filter housings come down with this in the wrong position! It causes exactly the symptoms you're having. Swap it to the same position as it was on your old housing and it'll work. Let us know how you get on
13th Jul 2014 5:04pm |
Any good?
15th Jul 2014 10:39pm |
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 |
Sorry should of replied sooner.
I checked all the valves as soon as the old one came off as I'd previously read about them being wherever the production line fancied them! So they were correct and then nipped up to seal! After swapping the lines around and with a fresh battery, a few cycles later and bit of starting on full throttle she eventually smoked into life and seemed to be ok so far! I'll update my other thread but the WJN000030 filter is bob on for the later TD5, so no need to spend 2.5x the price on WJN500150. |
16th Jul 2014 8:15am |
