Page 709 of 1392 <123 ... 708709710 ... 139013911392>
VeeTee
Netherlands
maar10 wrote:
Today Landreiziger gave my defender new alloys and wheels. I like them, a lot Smile
Are those Blindo wheels? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #344996 13th Jul 2014 9:07pm
JWL
Got my "retro" look finished tonight,
After getting shot of the A bar I have another plan for reattaching the spotlights and numberplate etc etc. It will be along these sort of lines
Post #345236 14th Jul 2014 10:09pm
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
What is that grille JWL? I'd really like something like that.
Post #345253 14th Jul 2014 10:54pm
JWL
I've had the thought for a fair time and doing a swop for a air-con panel on Saturday it finally kicked me into gear. The panel came off an '85 90 so a bit of cutting(oil cooler bit at the bottom) and filling(lock hole, fill in the bottom part where the starting handle goes through and the 3 fixing holes down each side) then paint. What did surprise me was that the panel is made of fibreglass, not aluminium.
The grill is just a 2m length of 6mm round bar shaped to fit the grill position, then a sheet of 0.8mm expanded aluminium(also gripfilled in the lower oil cooler part), and some 25mm galvanised weldmesh, all these cut to fit.
I did try to solder the mesh to the bar, unsuccessfully, hot glue had a partial success but all is immaterial as they are zip tied through holes drilled in the panel which sandwiches it all together using the round bar against the panel with the mesh bits inbetween.
New badge should be arriving in the post tomorrow to finish it off.
In all it's cost me about £20, paint, filler and mesh, other bits I had knocking around.
Here's part way through the creative process Whistle
Post #345258 14th Jul 2014 11:34pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
I like that john, but i think the abar needs to be modified and put back on imo 2004 TD5 Defender 90 xs station wagon
Post #345274 15th Jul 2014 7:07am
JWL
Finished the front today, made a small bar that sits in front and above the winch to hold the number plate, spotlights and Anderson connector. It now means that I can just undo 6 screws to take the whole grill panel off which will make it 10 times better to clean the radiators. Before the A bar was over the grill fixing screws plus the spotlights were pushing the grill as well which meant all that lot had to come off before you could even think about gaining access to the radiators.
Post #345370 15th Jul 2014 3:12pm
Now that has character and practicality written all over it! Cool
Thumbs Up
Post #345384 15th Jul 2014 4:17pm
mk1collector
Shoved a bit of rubber into the bonnet hinges to stop the annoying rattle Rolling Eyes it might be time for a visit to Brendan for some security hinges which should cure the rattling problem
Post #345385 15th Jul 2014 4:21pm
Have the plastic shims come out?
Post #345387 15th Jul 2014 4:24pm
mk1collector
No, I pushed the bit of rubber between the hinge and plastic shim
Post #345392 15th Jul 2014 4:42pm
Oh I see, must be very loose then. Confused
Post #345393 15th Jul 2014 4:55pm
gilarion
Finally got round to applying Dum Dum into the gaps around the bottom window rubbers to stop the water running down inside the door and out through the drain holes into the foot well.
I was glad that I bought two tins of Dum Dum before they stopped making it.
Post #345425 15th Jul 2014 6:57pm
airpusher
Wales 2006 Defender 110 Td5 XS DCPU Zambezi Silver
Managed to get time to fit the rocksliders!
Nothing's ever straight forward though! Had to modify the brackets to fit!
Oh and put the BoB led lights on! 2006 Defender Double Cab- Zambezi Silver
Post #345606 16th Jul 2014 5:12pm
Waldo
Designed, fabricated and fitted the bracket for my tow electrics today.
Will send it off to be powder coated next week
Will Defender 90 XS TD5 (03 Reg)
Post #345659 16th Jul 2014 9:13pm
maar10
Netherlands 2014 Defender 130 Puma 2.2 HCPU Corris Grey
@VeeTee yes blindo indeed!
Post #345706 16th Jul 2014 11:44pm
