![]() | Home > Technical > updating nanocom evo? |
willyj Member Since: 23 Oct 2009 Location: Carmarthenshire Posts: 204 ![]() ![]() ![]() |
How do I update my evo to include the 2011 puma onwards with newer abs?
cheers |
Cold_n_Wet Member Since: 15 Oct 2012 Location: Bergen Posts: 251 ![]() ![]() |
The 2,2 Puma support is in the canbus section apparently, not checked it my self yet, but will do when work calms down.
Nanocom site has the details for the upgrade, just did mine, downloaded the file, removed SD card, powered up via USB, set it in Kernel mode, and executed the Exe file. There is a guide in html format which also guides you through the steps. Glen "Rafiki" 2007 110 STW - Rolling rebuild. |
fatman Member Since: 14 Jan 2014 Location: Athens-Greece Posts: 126 ![]() ![]() ![]() |
The documentation for can bus version does not clarify if the bosch abs is indeed supported(or i looked at the wrong place
Have a look here
¨http://www.nanocom-diagnostics.com/viewproduct.php?productid=152 The unlock codes included in this kit will activate the software for the following Defender PUMA systems: Engine management, Instrument pack, Lucas 10AS, Wabco D ABS system and Bosch ABS which replaced the Wabco around 2010/11. Please see the Products page on the web shop for more detailed information of the capabilities with each ECU HTH Glen "Rafiki" 2007 110 STW - Rolling rebuild. |
Well...i updated to latest firmware,blackbox says that a can bus icon will be activated and gain some new functions with the same unlock codes i had..
Although i have a 2.4 puma,tomorrow i'll see if an option for bosch abs also appears on screen. |
