Home > Technical > updating nanocom evo?
willyj
United Kingdom 2011 Defender 110 Puma 2.4 USW Stornoway Grey
How do I update my evo to include the 2011 puma onwards with newer abs?
cheers
Post #343812 8th Jul 2014 8:52pm
fatman
Greece 2007 Defender 110 Puma 2.4 USW Keswick Green
It's been a while since i updated my nanocom but i don't think they released a newer update that covers the bosch abs,in fact they don't offer anything new for the Puma 2.4 or 2.2 Crying or Very sad
I'd like some extra functions for calibrating the fuel pump,injectors or even a security learn function for the as10 and engine ecu as on td5 ecu's... Confused Confused
Post #343986 9th Jul 2014 1:07pm
Cold_n_Wet
Norway
The 2,2 Puma support is in the canbus section apparently, not checked it my self yet, but will do when work calms down.
Nanocom site has the details for the upgrade, just did mine, downloaded the file, removed SD card, powered up via USB, set it in Kernel mode, and executed the Exe file.
There is a guide in html format which also guides you through the steps.
Glen "Rafiki" 2007 110 STW - Rolling rebuild.
Post #344012 9th Jul 2014 3:30pm
fatman
The documentation for can bus version does not clarify if the bosch abs is indeed supported(or i looked at the wrong place Embarassed ),you'd better post a question at this forum http://nanocom.blackbox-solutions.com/index.php/forum
Post #344227 10th Jul 2014 1:15pm
Cold_n_Wet
Norway
Have a look here
¨http://www.nanocom-diagnostics.com/viewproduct.php?productid=152
The unlock codes included in this kit will activate the software for the following Defender PUMA systems: Engine management, Instrument pack, Lucas 10AS, Wabco D ABS system and Bosch ABS which replaced the Wabco around 2010/11. Please see the Products page on the web shop for more detailed information of the capabilities with each ECU
HTH
Post #344233 10th Jul 2014 1:31pm
fatman
Well...i updated to latest firmware,blackbox says that a can bus icon will be activated and gain some new functions with the same unlock codes i had..
Although i have a 2.4 puma,tomorrow i'll see if an option for bosch abs also appears on screen.
Post #344306 10th Jul 2014 7:49pm
