![]() | Home > Maintenance & Modifications > Stainless front bumper bolts |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2788 ![]() ![]() |
Where can I get them?
Got the full kit from Brendan which is great(well worth it if you're a bit OCD like me) but no bumper bolts which is a shame considering they're probably the most obvious bolts on the car and they all rust it seems. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
david mitchell Member Since: 01 Jul 2012 Location: Meath Posts: 419 ![]() ![]() ![]() |
Try flatdog
ISTR buying a kit from eBay, because it was easy and they came with nice plastic covers for the bolt heads. I've just had a quick look and there are loads to choose from, including from site sponsor, MPS. Darren
Got some from flatdog on eBay, Ł12 free P&P and plastic caps included. Will report back what they're like Cheers, David
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2666 ![]() ![]() ![]() |
I used Stigs...
http://www.a2stainless.co.uk/Land-Rover-De....aspx?nh=5 Happy with the purchase, speedy delivery & good prices... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Black plastic caps on the heads are surely all you need to tidy up the front end? Maybe with stainless washers if the orignals start to discolour.
Supacat sed;
"HAMMERITE on the heads are surely all you need to tidy up the front end? Maybe MOAR HAMMERITE if the orignals start to discolour". Edited for accuracy ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20919 ![]() ![]() |
If you really want a top job on the bolt heads painted. (If you don't get caps which I would)
Would be to mask off the heads, etch prime, top coat paint then. Ideally with a clear coat over that too. Then it won't flake! Trouble is get a ratchet on there and it's done for straight away. |
Now if you'd said POR-15... |
Haha I'm not that sad as to paint bolt heads!
![]() Stainless ones will be here soon, job done. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3797 ![]() ![]() ![]() |
Where would one buy the caps?
Pickles. |
E-bay or similar is easiest. Or a fixings supplier, should be for the bolt size I.e. M10 cap.
Thanks, so they were never a genuine L.R. item?
Pickles. |
Nope - never standard, but get yourself a selection pack and there's all sorts of bolts head, but more importantly nuts and exposed threads that they can cover and protect a little from corrosion especially if you pack them with grease or copperslip.
