Home > Maintenance & Modifications > Stainless front bumper bolts
Cheshire110
Where can I get them?
Got the full kit from Brendan which is great(well worth it if you're a bit OCD like me) but no bumper bolts which is a shame considering they're probably the most obvious bolts on the car and they all rust it seems. Cheers, David
Post #343111 5th Jul 2014 11:11pm
david mitchell
Ireland 2003 Defender 90 Td5 HT Epsom Green
Try flatdog
Post #343116 5th Jul 2014 11:28pm
I second above, they come with the correct captive nuts too not just regular nuts.
Makes things much easier.
I fitted a pair with another D2 member AlisterC earlier this year.
Post #343117 5th Jul 2014 11:31pm
ISTR buying a kit from eBay, because it was easy and they came with nice plastic covers for the bolt heads. I've just had a quick look and there are loads to choose from, including from site sponsor, MPS. Darren
Post #343123 6th Jul 2014 7:58am
Cheshire110
Got some from flatdog on eBay, Ł12 free P&P and plastic caps included. Will report back what they're like Cheers, David
Post #343246 6th Jul 2014 7:54pm
MartinK
I used Stigs...
http://www.a2stainless.co.uk/Land-Rover-De....aspx?nh=5
Happy with the purchase, speedy delivery & good prices... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #343327 7th Jul 2014 7:35am
Black plastic caps on the heads are surely all you need to tidy up the front end? Maybe with stainless washers if the orignals start to discolour.
Post #343399 7th Jul 2014 11:01am
jimbob7
Supacat sed;
"HAMMERITE on the heads are surely all you need to tidy up the front end? Maybe MOAR HAMMERITE if the orignals start to discolour".
Edited for accuracy Thumbs Up ! Pov.spec,ftw. 2006, 110,TD5.
Post #343403 7th Jul 2014 11:07am
If you really want a top job on the bolt heads painted. (If you don't get caps which I would)
Would be to mask off the heads, etch prime, top coat paint then. Ideally with a clear coat over that too.
Then it won't flake!
Trouble is get a ratchet on there and it's done for straight away.
Post #343405 7th Jul 2014 11:10am
jimbob7 wrote:
Supacat sed;
Now if you'd said POR-15...
Post #343516 7th Jul 2014 6:16pm
Cheshire110
Haha I'm not that sad as to paint bolt heads! Rolling with laughter
Stainless ones will be here soon, job done. Cheers, David
Post #343535 7th Jul 2014 7:29pm
Pickles
Where would one buy the caps?
Pickles.
Post #343611 7th Jul 2014 11:22pm
E-bay or similar is easiest. Or a fixings supplier, should be for the bolt size I.e. M10 cap.
Post #343613 7th Jul 2014 11:33pm
Pickles
Thanks, so they were never a genuine L.R. item?
Pickles.
Post #343614 7th Jul 2014 11:44pm
Nope - never standard, but get yourself a selection pack and there's all sorts of bolts head, but more importantly nuts and exposed threads that they can cover and protect a little from corrosion especially if you pack them with grease or copperslip.
Post #343719 8th Jul 2014 3:20pm
