Home > Technical > Removing Loading Bay Floor - 110 DC
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
Hi All,
In a quest to determine if my FP is on it's last legs, I've been looking at ways to access the pump whilst in situe (not sure in the spelling there?) and connected making it easier to diagnose.
I realise the 'normal way' is the drop the tank, but id have to drop the tank, rig the pump to test, refit said pump and tank, then order one, then drop again etc etc, so looking into the access hatch type set-ups. Plus I've always pretty much got a brimmed tank and I dont have enough Jerry cans to store it all!
I've read most of the google results and have built up a list of dimensions and measurements all differing to each other, but all for a 110. Does anyone have some specifics for a DC, just so I can be sure.
I realise most have had to cut some of the strengthening beams also. I'm trying to avoid this and I'm sure someone managed it. A little awkward to remove the pump, but manageable, but I cant find that thread any more! Someone definitely managed it and posted pictures!
So my plan is the remove the rear load bed entirely, then see what sort off access is there. Being the DC, it doesn't matter if I run around around a while with it off. The iForWilliams back cover makes so much noise it probably wont make any obvious change!
This will then let me work out if it's possible to make a hatch without cutting out the braces, or maybe just flinching them slightly to allow the pump to be removable.
So all this is basically asking, how easy is it to remove the load bed? Is it all pop riveted on? If so, I could potentially just reinstall using riv-nuts (love those things or DZUS) and maybe just have the whole thing as removable and save cutting a hatch ...
Again, I'm sure someone did thread, but my search efforts have proven un-fruitful.
I appreciate I could just go and attack it, but I always like to ask and be sure of myself!
Advice appreciated and thanks to all.
Post #342728 4th Jul 2014 11:12am
rallysteve
I'm afraid its a no-go trying to remove the floor panel in a DC. As the rear body is that of a station wagon the floor extends right upto the underside of the back seats. Therefore the load area bulkhead effectively sandwiches the floor to the chassis.
If you follow the dimensions to cut an access hole however for any 110 td5 model you should have no problem as the tank is the same and in the same location.
I cannot comment on the floor braces as I haven't taken the floor out of our DC
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale
Post #342740 4th Jul 2014 11:42am
It's really not difficult to drop the tank on a 110, especially on a DC which doesn't have an ARB. I have removed mine twice for various reasons (it's a TDCi but there's no significant difference) and even including taking off the DB adjustable towbar it only takes 1/2 hour to remove and about the same to refit. You will want as little fuel as possible in the tank though.
Another advantage is that you can clean the inevitable black "diesel bug" slime out of the tank while you're at it.
I reckon that I could drop and refit my tank in less time than it takes to cut a hole in the floor and make good afterwards.
Post #342741 4th Jul 2014 11:49am
taazzukcb
I know it's theoretically quick enough to drop, but knowing my luck, things wont be simple and rust will cause me severe issues!
Is there a tank drain plug at all (should go out and look, but currently at work, might nip out at lunch!)? Most weekends I have a pretty full tank, so would have to drop it, then refill it. It's just fact of having to the job 2 or 3 times as I cant afford to have a pump 'on-standby' with the £250 price tag, plus having to rig up an external way of testing the pump. In situe, this is all set-up already ... And makes potential trouble shooting elsewhere more simple.
Not sure what to do ...
Would make future (inevitable) failures easier to. Just dont want to go cutting the braces!
Post #342758 4th Jul 2014 12:28pm
JWL
I did mine, a station wagon recently, and cut the access hole for mine. If you look for http://www.defender2.net/forum/topic28189.html. You'll find pictures in the thread. You don't cut the braces off, just trim them to give you a bit more room. It's not a difficult job, bit fiddly to keep things neat but if you're going to put a access hole cover you can make a really tidy job, mine has a built in ply box in the back so the floor is covered anyway so you can't see it.
With the hole in there now I know that I could do a pump change in around 20 minutes, most of that would be taken up with emptying the junk out of the box to get to the cover. No worrying about how much fuel is in there, disturbing the tow bracketry and only needs a screwdriver, can be done on the side of the road if necessary.
Post #342767 4th Jul 2014 12:57pm
taazzukcb
Had a quick look.
No drain. Would of been handy if there was! I only filled up yesterday, so I will have to run it through next week and maybe fill up a 20ltr Jerry to fill the tank once back on.
Bolts dont look to bad. 2x Nuts in the rear crossmember and 2 Hex Bolts underneath. Just hope what I assume to be welded nuts on the other side are still solid!
I may still consider a small hatch for future, but will make one as to avoid the bracing. Maybe enough to just get hands in and see what's going on. Once the tanks out I can just cut one of the inner oblong sections out in between the brace rails. Load bed is lined anyway and I was considering some 3mm Chequer Plate anyway.
On a side note, by exhaust joint looked like a dried out cookie. Using my finger I basically broke a good 80% of one of the nuts off! Pipes dont looks bad, but blimey them bolts look shagged! May need to get the A-Frame off to and get some fresh nuts and bolts there to before they get the point of no return!
Post #342769 4th Jul 2014 12:59pm
taazzukcb
Oh yes, the tow bar bracing has to come off to by the looks of it!
JWL: Link not working, but think I've read through it before. I'm still 50/50 on what to do, so will have another read through! It's the quick access I like!
Post #342771 4th Jul 2014 1:02pm
JWL
It's not too scary to do, you've got a good inch and more on the 3 sides away from the front facing edge and even that has at least a half inch of space under the floor. Plenty of room to use a 115mm grinder with a thin cutting disc, cutting away at the braces is preferred to give you room to get your hands in. Once done you'll be wondering why you ever thought of dropping the tank!
Post #342776 4th Jul 2014 1:13pm
JWL
Sorry about the link, it seems my tablet doesn't like copy and paste. The title was "Access to a fuel pump Td5" in the Maintenance and Modifications section on this forum.
Post #342780 4th Jul 2014 1:22pm
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
Hi, did mine at weekend-10 mins with grinder/chisel, floor is spot welded to north south stiffener.. Cut east west steel stiffener, no way you can get pump and hands in there.. Make sure you get rubber seal on pump seated on tank before you push pump down( it's spring loaded, fun to do big knurled nut up!!..) I got a pump from Craddocks for £80 odd plus dreaded, not britpart and looks identical to original... My dc has an anti roll bar.. And it's ' in situ'..... Thumbs Up do it!!
Hope that helps!!
Cheers. Alex
Post #344156 10th Jul 2014 12:50am
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Be very careful of buying cheap pumps that fail quickly.
Best to get OEM quality for longer life Thumbs Up
Easy to fit once the hole is cut in the floor.
Big thanks to Ian from IRB for his help in hole cutting!!
Post #344188 10th Jul 2014 8:49am
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
done the same here....have the measurements if you want them for cutting in the right place.. Putting Dreams on Drives at JLR Solihull..
Post #344204 10th Jul 2014 10:43am
taazzukcb
Before I go for a pump, I'm going to try injector seals and o-rings, fuel pressure regulator and also the fuel filter body (and filter of course), which all need doing anyway.
Adafish, if you have the dimensions then it would be great if you could post them, so that I have them at the ready. Even if this does cure the issues temporarily, with me just about to hit 92,000, I'm pretty sure the pump wont be far off now! Especially with it having to work extra hard the past couple weeks!
As to pumps, I will probably stick to Siemens/VDO OEM.
Post #344220 10th Jul 2014 12:45pm
taazzukcb
Is it only the E-W stiffener that has to be cut too?
Post #344221 10th Jul 2014 12:45pm
