![]() | Home > Maintenance & Modifications > Sankey/LED bulbs questions |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
1. Yes, they're just standard fitment as you might use in a car.
2. The wiring is the same but if you want to use LED indicators then you'll need to incorporate ballast resistors to provide sufficient load for the vehicle flasher unit to recognise them. Without, you won't get the trailer flasher indicator in the cab. That all assumes a reasonbly standard towing vehicle. If you've already got LED's and a different flasher unit in the towing vehicle then all bets are off. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
| muddybaldboy Member Since: 09 Apr 2012 Location: Ruthin Posts: 395
Any recommendation for a quality supplier |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939
LED fixtures in incandescent (standard) light holders aren't legal.
You'd be better off with buying LED light units. They will be E marked and thus legal to use on the road. |
| GUM97 Member Since: 05 Feb 2012 Location: Cheshire Posts: 3555
But it'd never fail an MOT with them in...because it's a trailer...
And, the MOT checks for light intensity/output, which LED's have much more significantly than incandescents. An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
GUM, you'll never get anywhere in this life, you talk too much sense
The powers that be dont like that, but I do So assuming I was replacing the LED bulbs on my approved LED lights |
Try Autobulbs Direct.
Yep, AutoBulbs direct
It's very unlikely that military lights with screw on lenses are e-marked in the first place. Site sponsors Advanced Factors sell some good LED bulbs. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
That is true in hindsight as mentioned above, I guess it depends on age and even then questionable.
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582
The chances are that UK military vehicles come under Crown exemption rules so the fact that they may or maynot be E marked or more correctly type approved is irrelevant.
Type approval is required on obligatory lights and the age of vehicles and other considerations are set down in the Vehicle Lighting Regulations. Am not sure how VLR apply to trailers but would assume brake/tail and indicators should be type approved as they would be obligatory lights. Brendan |
Thanks very much everyone
