Home > Maintenance & Modifications > Sankey/LED bulbs questions
muddybaldboy
Wales 1999 Defender 110 Td5 HT Chawton White
I'm about to rewire (gut) one of my older Sankeys to swap over to 12v. I'd like to keep the original screw on lens miltary lights but have a couple of questions.
1st Can i get direct fit 12v LED bulbs that fit
2nd Do the need any differnet wiring (keep seeing mention of ballast) I've rewired trailers before but never gone LED.
Any help appreciated Bow down He who dies with the most toys...wins!
Post #342487 3rd Jul 2014 12:41pm
1. Yes, they're just standard fitment as you might use in a car.
2. The wiring is the same but if you want to use LED indicators then you'll need to incorporate ballast resistors to provide sufficient load for the vehicle flasher unit to recognise them. Without, you won't get the trailer flasher indicator in the cab.
That all assumes a reasonbly standard towing vehicle. If you've already got LED's and a different flasher unit in the towing vehicle then all bets are off. Darren
Post #342490 3rd Jul 2014 12:50pm
muddybaldboy
Cheers Thumbs Up
Any recommendation for a quality supplier Question He who dies with the most toys...wins!
Post #342491 3rd Jul 2014 12:51pm
LED fixtures in incandescent (standard) light holders aren't legal.
You'd be better off with buying LED light units. They will be E marked and thus legal to use on the road.
Post #342494 3rd Jul 2014 12:52pm
GUM97
But it'd never fail an MOT with them in...because it's a trailer...
And, the MOT checks for light intensity/output, which LED's have much more significantly than incandescents. An engine to TDi for!
Post #342498 3rd Jul 2014 1:17pm
muddybaldboy
GUM, you'll never get anywhere in this life, you talk too much sense Wink
The powers that be dont like that, but I do Whistle
Thumbs Up
So assuming I was replacing the LED bulbs on my approved LED lights Wink , Anyone know any suppliers of quality items? He who dies with the most toys...wins!
Post #342502 3rd Jul 2014 1:31pm
Try Autobulbs Direct. Thumbs Up
Post #342503 3rd Jul 2014 1:33pm
GUM97
Yep, AutoBulbs direct Thumbs Up An engine to TDi for!
Post #342511 3rd Jul 2014 2:13pm
It's very unlikely that military lights with screw on lenses are e-marked in the first place.
Site sponsors Advanced Factors sell some good LED bulbs. Darren
Post #342512 3rd Jul 2014 2:14pm
That is true in hindsight as mentioned above, I guess it depends on age and even then questionable.
Post #342528 3rd Jul 2014 2:53pm
leeds
The chances are that UK military vehicles come under Crown exemption rules so the fact that they may or maynot be E marked or more correctly type approved is irrelevant.
Type approval is required on obligatory lights and the age of vehicles and other considerations are set down in the Vehicle Lighting Regulations.
Am not sure how VLR apply to trailers but would assume brake/tail and indicators should be type approved as they would be obligatory lights.
Brendan
Post #342538 3rd Jul 2014 3:39pm
muddybaldboy
Thanks very much everyone Thumbs Up He who dies with the most toys...wins!
Post #342721 4th Jul 2014 10:14am
