Home > Td5 > Lazy throttle pedal
excossack
Lazy throttle pedal
On my 1999 TD5 the throttle pedal is lazy, 1" of travel before the revs increase.
So, I got it plugged into an Autologic box and as soon as the pedal is press the volts(?) on the display change but the revs don't change,
On seeing this, the pedal is doing its job? but the ECU appears to slow in responding to the changes.
Any thoughts?
By the sounds of it I don't need to buy a new pedal, I just need the ECU poking into life so the response is quicker...? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #342353 2nd Jul 2014 9:58pm
Martin
Site Admin
Does it change if you put it in low box?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #342356 2nd Jul 2014 10:09pm
excossack
Errr good call...Will check tomorrow. 1999 Defender TD5 110
Regards
John M0VAZ
Post #342357 2nd Jul 2014 10:12pm
excossack
Still the same in Low box 1999 Defender TD5 110
Regards
John M0VAZ
Post #342465 3rd Jul 2014 12:05pm
It might be worth checking that the high/low range switch isn't stuck in the low position before you replace anything more expensive. I think that the switch is open in high and closed in low, in which case you could try unplugging the connector above the front output housing on the transfer box (there are two connectors, one is the high/low switch and the other the difflock switch. Unfortunately they are really inaccessible unless you take the panel between the front seats out and work from above).
Alternatively a diagnostic tool such as Faultmate can probably read the input from the switch and you should see if it is working (although ISTR that faultmate has the readings transposed, ie is says high when you're in low and vv. The important check is that the reading changes when you move the transfer selector).
Post #342471 3rd Jul 2014 12:12pm
excossack
Is that the panel under the cubby box / middle seat? 1999 Defender TD5 110
Regards
John M0VAZ
Post #342474 3rd Jul 2014 12:16pm
roel
Yes Roel
2003 90 Td5 (2009-now)
Post #342489 3rd Jul 2014 12:49pm
excossack
Cheers all. 1999 Defender TD5 110
Regards
John M0VAZ
Post #342513 3rd Jul 2014 2:19pm
excossack
I'd forgotten about this thread!
The only update I have is, the MAF has been swapped and the transfer case is now a Disco one with no High/Low switch and the pedal is still the same. 1999 Defender TD5 110
Regards
John M0VAZ
Post #400563 20th Feb 2015 1:50pm
Give the potentiometer a good squirt of wd40.. QRZ 2e0vpf
Post #400567 20th Feb 2015 2:02pm
landy andy
Got a spare potentiometer here if you need. What have you done with high low wires. Left unconnected or joined them?
May be worth while trying the two options. Pedal should work differently in high compared to low.
Andy
Post #400571 20th Feb 2015 2:07pm
excossack
The high/low has been left as is not connected AFAIK
The spare potentiometer could be a good move, is this the same across all years? 1999 Defender TD5 110
Regards
John M0VAZ
Post #400572 20th Feb 2015 2:11pm
excossack
WD40 or contact cleaner? Is the potentiometer hidden under a cover? 1999 Defender TD5 110
Regards
John M0VAZ
Post #400574 20th Feb 2015 2:11pm
Yeah, mine on the Ibex was not working, even though it was put on the bulkhead, to keep it out of harms way Laughing
wd or anything really will do.
A quick strip and squirt Very Happy had it sorted.
here's a pic from my Ibex, so you know what you're looking for.
 QRZ 2e0vpf
Post #400579 20th Feb 2015 2:19pm
excossack
Cheers GreenI. Yours is cable operated I guess?
I shall have a look over the weekend and see what I can see. Mine is in the normal place in the footwell. 1999 Defender TD5 110
Regards
John M0VAZ
Post #400580 20th Feb 2015 2:21pm
