![]() | Home > Td5 > Lazy throttle pedal |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6700 ![]() ![]() ![]() |
Does it change if you put it in low box?
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6021 ![]() ![]() ![]() |
Errr good call...Will check tomorrow. 1999 Defender TD5 110
Still the same in Low box 1999 Defender TD5 110
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17921 ![]() ![]() ![]() |
It might be worth checking that the high/low range switch isn't stuck in the low position before you replace anything more expensive. I think that the switch is open in high and closed in low, in which case you could try unplugging the connector above the front output housing on the transfer box (there are two connectors, one is the high/low switch and the other the difflock switch. Unfortunately they are really inaccessible unless you take the panel between the front seats out and work from above).
Alternatively a diagnostic tool such as Faultmate can probably read the input from the switch and you should see if it is working (although ISTR that faultmate has the readings transposed, ie is says high when you're in low and vv. The important check is that the reading changes when you move the transfer selector). |
Is that the panel under the cubby box / middle seat? 1999 Defender TD5 110
Yes Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Cheers all. 1999 Defender TD5 110
I'd forgotten about this thread!
The only update I have is, the MAF has been swapped and the transfer case is now a Disco one with no High/Low switch and the pedal is still the same. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Give the potentiometer a good squirt of wd40.. QRZ 2e0vpf
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5988 ![]() ![]() |
Got a spare potentiometer here if you need. What have you done with high low wires. Left unconnected or joined them?
May be worth while trying the two options. Pedal should work differently in high compared to low. Andy |
The high/low has been left as is not connected AFAIK
The spare potentiometer could be a good move, is this the same across all years? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
WD40 or contact cleaner? Is the potentiometer hidden under a cover? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Yeah, mine on the Ibex was not working, even though it was put on the bulkhead, to keep it out of harms way
![]() wd or anything really will do. A quick strip and squirt ![]() here's a pic from my Ibex, so you know what you're looking for. ![]() Click image to enlarge QRZ 2e0vpf |
Cheers GreenI. Yours is cable operated I guess?
I shall have a look over the weekend and see what I can see. Mine is in the normal place in the footwell. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
