Home > Tdi > Petrol in Diesel |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I think I would put more than a gallon of diesel in the tank. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
30th Jun 2014 8:19am |
pob1968 Member Since: 20 Apr 2014 Location: uk Posts: 239 |
Do you mean put a gallon of petrol in your tdi?
Petrol and diesel engines operate quite differently - compression ignition - diesels as in they compress the fuel air mix until it explodes rather than a petrol engine that ignites the fuel air mix with a spark plug. With trhis in mind I would be careful mixing the two. 110 Hardtop |
30th Jun 2014 9:34am |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
It used to be common to add petrol to diesel to prevent the diesel waxing in the winter but that was before winter grade diesel and modern Diesel engines, not sure I would want to add anything that would reduce the lubricity of the diesel as this is what stops your injection pump turning to swarfe.
Just my opinion of course. 2005 Td5 90 XS Steve |
30th Jun 2014 10:02am |
have you searched on forum about 2 stroke oil in diesel |
30th Jun 2014 10:15am |
Yes and modern injectors work at such small tolerances and at such high pressures you have to be careful what you put in. 110 Hardtop
30th Jun 2014 11:00am |
The look on a customer's face when I handed him a bill for just shy of £3,000 as a result of putting some petrol in a Diesel "because he though it'd be alright" suggests that it's not such a good idea. Don't do it. 2 stroke is a different story though... An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
30th Jun 2014 11:47am |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5085 |
add a shot of Millers ECOMAX to your tank.
■Up to 7% improvement in fuel economy ■Improves engine response and power delivery ■Cleans injectors and fuel system – ensuring optimum performance ■More complete combustion – reducing soot, and NOx emissions ■Cost effective ■Easy to use |
30th Jun 2014 1:54pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2290 |
Hi cornish rattler
If you're asking what I think you're asking... a small amount of petrol, in a tank otherwise full of diesel NO...DON'T DO IT A good 'additive' to a tank of Diesel (the benefits are however debatable) but A spare can of Diesel for long journeys A long range tank A properly maintained Defender But avoid the Green Nozzle at filling stations SKIP https://www.defender2.net/forum/topic83242.html |
30th Jun 2014 4:45pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
As above really, don't do it.
Petrol and diesel systems are very different, petrol can cause the seals and rubbers to swell or leak in diesel systems, as well as cause increased wear on your injectors and pump. This combined with no benefits at all performance wise (can cause pre-ignition too which is very bad for your pistons, cranks, crankshaft, bearings) I cannot see any benefit to it. Yes if you bought diesel in the Sahara and then drove to Iceland, maybe put a little in to a full tank, otherwise just use diesel. The Tdi lumps are very forgiving with quality of diesel, they can chew up some pretty cruddy diesel unlike modern common rail lumps. But they don't like petrol. In my lump I run standard BP Diesel and put in an additive. In my opinion it runs better with the additive though I have no actual figures or numbers to back this up. |
30th Jun 2014 6:21pm |
caterham6 Member Since: 18 May 2014 Location: Manchester Posts: 47 |
http://www.bp.com/en_za/on-the-road/south-...iesel.html is the only way to Go!
30th Jun 2014 7:26pm |
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 |
Ok cheers guys i will leave putting petrol in then but mite look into trying some millers instead, its only i am going to billing in a few weeks time and don't no the con'd of the injectors so thought while i am driving a fair distance i will put something in the fuel system to help clean the injectors wether they need it or not Graham
1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
2nd Jul 2014 12:53am |
To be honest just a full tank of good diesel and some redex should clear through any crud on a nice long run and everything will get nice and warm so hopefully should give it a bit of a boost
2nd Jul 2014 6:31pm |
Try one shot of millers DIESEL INJECTOR CLEANER they recomend a journey of about two hundred miles on a full tank so Billing should about do that http://www.millersoils.co.uk/automotive/td...sector=Car Try Land Ranger Service in Stockport to see if they stock it.... |
2nd Jul 2014 7:25pm |
Cheers gilarion i will do that as i need to go there on Saturday anyway to see about some welding i need doing so i will pick some up Graham
3rd Jul 2014 12:20am |
