![]() | Home > Maintenance & Modifications > Bulkhead mounted spare wheel |
Mud Dog Member Since: 11 Jul 2013 Location: Kent Posts: 31 ![]() ![]() |
Hi,
I've got a 2002 90 and want to mount my spare wheel (285 75 r16) against the bulkhead. I've seen the old series bracket but don't know if it will fit the bill. Anyone done this or have any thoughts? The only other thing I fount was this: http://www.allbrit.de/UNI.cfm?PAGE=770895&...SPRACHE=EN Any advice would be welcome Thanks We're not stuck...just enjoying the scenery! |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1777 ![]() ![]() |
I would think the spare wheel mounting bracket from a double cab will do the job nicely
I also have the original wheel carrier from the rear door of my 08XS. I am heading to Kent tomorrow, you're welcome to it free-gratis if it's any use.
![]() Treat every day as if it is your last....one day you will be right!! |
Mine used to be mounted to the bulkhead, but for the life of me I can't remember how it attached
![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
My Defender came with what looks like an older version of the rear door mount bolted to the bulkhead.
One of these. ![]() Click image to enlarge Pov.spec,ftw. 2006, 110,TD5. |
paulnb57 Member Since: 18 May 2011 Location: Isle of Wight UK Posts: 38 ![]() |
The problem when using the mount from a rear door is that a flat tyre would no longer touch the floor and put a lot of strain on the centre bulkhead......
Paul |
More strength in the bulkhead than the door,anyways I wouldn't bother mounting a flat tyre, just throw it on the floor. Pov.spec,ftw. 2006, 110,TD5.
Might as well throw the good one on the floor then!??
Paul |
